Mesh configuation with two Tap200
I made the configuration for my MESH following this site.
I use a TutM10 and two Tap200. The configuration is working, when I connect one Tap200 to the RutM10. When I connect both Tap200 to the RutM10, the Network is not working. Ping on all 3 devices is from <1ms to timeout. Login on any device is not possible. The internet for the RutM10 comes from a FritzBox 7490. When both Tap200 are connected, it shows internetconnection, but try to open google.com, there comes a timout.
The same problem I have, when I try to connect both Tap200 directly to my FritzBox. When only one Tap200 is connected to the FritzBox, everything is worging. When I connect both to my FritzBox, I have no internet and I get also timeout on ping to my Fritzbox.
There is no difference, when I change the IP Settings of both Tap200 from DHCP to fixed IP.
Both Tap200 are running with firmware TAP200_R_00.07.20.3.
What’s to do, to fix it?
I made some changes and now it look’s good.
At first I changed from DHCP to fixed IP for the two TAP200. Same problem, but it’s easier to handle.
Than I give all Mesh Nodes a separate MeshID. So the MeshID for the RitM10 is Demo-1.1 and Demo-1.2 for 2.4 and 5GHz. TAP200-1 has Demo 2.1 and 2.2 and TAP200-2 has Dem-2.3 and 2.4. In this configuration the network is running and I have internet on 2.4 and 5 GHz. I can communicate over the hole LAN and WAN. Wireguard from outside is also working.
