Hello, Is it possible to manually delete/remove a DHCP lease without rebooting the device?
This specifically pertains to passthrough mode where we have a RUT assigning the static public IP to our downstream client/device. It would be nice if we could disconnect the ethernet cable between the LAN port on the RUT and the downstream client/device, remotely (via web interface or RMS) remove the DHCP lease, then connect our laptop to RUT LAN port and have the public IP assigned (without having to first reboot the device to clear the existing lease). Likewise, this would save having to reboot RUT again when we reconnect the main downstream client/device (in order for it to get the static public IP).
Thank you.
