Management VLAN over Tinc L2 VPN on RUTX08
Hello! I’m trying to replicate a working setup from a dedicated Linux machine onto a RUTX08 router.
We’re using a Tinc VPN in switch mode, carrying multiple VLANs. The VPN connection is established successfully and tagged traffic is visible across the tunnel.
So far:
  • I’ve configured a port-based VLAN with ID 10 (untagged) on LAN port 3 “eth0.10”.
  • I’ve created a bridged LAN interface (br-lan) bridging “eth0” and the “tinc_VPN” interface.
This setup works well: devices connected to LAN 3 can reach the remote network over VLAN 10.
Now, I’d like to access the RUTX08 itself via the VPN, using VLAN 9.
My first approach was to create a VLAN interface on the “br-lan” bridge with an assigned IP, but I couldn’t figure out how to do this, interface-based VLAN options don’t seem to allow bridge selection.
My second idea was to define a VLAN on the “tinc_VPN” interface and assign an IP address directly to the RUTX08, but again, I can’t figure how to do this.
Has anyone configured something similar or can offer guidance on enabling management access to the router via a specific VLAN over a Tinc layer 2 tunnel?
Any insights would be greatly appreciated!
Thank you for reaching out. I believe, to assist and understand the intended setup effectively, we’ll need to continue this process privately. You should find a support request form in the inbox of the email address you used for your forum registration. Kindly fill out the form, and please reference Ticket ID: 14411 when submitting it. Once the form is completed, we’ll contact you directly via email to investigate and gather the necessary details to help work towards a solution.
