Please tell me, do the settings of “RUTX11/RUTX12” allow you to use a mobile antenna to create a local network?
Can I use the mobile output (SMA for LTE) without using a SIM card? Can I configure the router to communicate with another router via an antenna connected to the mobile connector, or is only Wi-Fi available for this?
I understand that in most countries the LTE band is regulated, but this case will apply in unregulated territories.
Thank you!
The RUTX11/RUTX12 routers allow you to use a mobile antenna to connect to a cellular network, which can then be shared with your local network devices via LAN or Wi-Fi. However, please note the following specifics:
- The mobile antenna is specifically designed for LTE connections. It cannot be used for other purposes without a SIM card inserted into the router.
- Direct communication between routers via the mobile (LTE) connectors is not supported. The LTE antennas are intended solely for establishing connections to cellular networks. To communicate between RUTX11/RUTX12 routers, you should use Wi-Fi or Ethernet connections.
If you have any further questions or need clarification, please let me know.
