Lost default password for RUT200 (sticker damaged)
Hello. The factory sticker on the back of my RUT200 router is completely damaged and scratched off, so I cannot read the default password. After a full factory reset, the router broadcasts a Wi-Fi network named RUT200_6204.
Could you please help me recover the unique factory Admin Password and Wi-Fi password from your database using this MAC address ending (6204)? I can provide a photo of the device if needed. Thank you!
If your device is not accepting admin/admin01 as username and password, that means you have batch 5 which uses unique password printed on the label. Teltonika is not keeping any records of these passwords for security reasons and they can not help you with password recovery. Your only option is flashing 3rd party OpenWRT firmware which can be found here.
Hello, @ArmanArman
Welcome to community. :sunglasses:
I am not a Teltonika employee.
But… Sorry to write this…
The only way from now to keep your device working is replacing RutOS firmware with openwrt standart firmware.
But… I can be wrong.
Thank you for your suggestions. Unfortunately, none of the software methods worked:
  1. Firmware Downgrade: I successfully downgraded the router to an older factory firmware version (RUT2M_R_00.07.03.4_WEBUI.bin). However, even on this older version, the router still rejects the default admin / admin01 credentials. It seems the unique password from Batch 5 is hard-coded into the protected commercial memory partition and cannot be bypassed by simply changing the RutOS version.
  2. Flashing OpenWrt: I tried uploading both the squashfs-factory.bin and the sysupgrade.bin OpenWrt images through the Bootloader menu (192.168.1.1/index.html). In both cases, the bootloader rejects the files with an “incorrect firmware file” error due to strict header validation and digital signature checks.
    Since the original sticker is completely scratched off and destroyed, the router is completely locked. Is there any way to bypass this bootloader signature check to install OpenWrt, or is physical chip flashing via an external programmer (like CH341A) the only option left for this device?
Hi…
First step need to use KERNEL firmware.
Not working…
You will need to do the TFTP procedure to your upgrade openwrt to your device.
Sample…
  1. Set Up the TFTP Server:
    • Download and open Tftpd64 on your PC.
    • Place your OpenWrt factory firmware file into the Tftpd64 directory.
    • Rename the OpenWrt file to something simple, like openwrt.bin.
    • Set your PC’s static IP to 192.168.1.254 (Subnet: 255.255.255.0).
  2. Access the Bootloader CLI:
    • Connect your PC to the router’s LAN port.
    • Open a terminal application (like PuTTY or Tera Term) and open a Telnet connection to 192.168.1.1 on port 23 (or port 5000 depending on the bootloader version).
    • Power on the router while holding the physical RESET button for 5–8 seconds to ensure it stays in bootloader mode.
  3. Force-Flash the Firmware:
    • Once connected to the bootloader terminal interface, pull the file from your PC by running a command similar to:
SAMPLE
tftp 0x80060000 openwrt.bin
Once the file transfers successfully into memory, issue the bootloader write command to overwrite the flash partition:
SAMPLE
erase linux
cp.b 0x80060000 0x9f050000 $filesize
boot
(Note: Exact memory addresses can vary slightly by hardware revision. If the CLI rejects the commands, the device will need to be flashed using a standard USB-to-TTL Serial adapter connected directly to the internal pins of the motherboard).
We understand that these situations can be frustrating and cause inconvenience, especially when a damaged label prevents you from accessing your device.
According to our security guidelines, we do not store default device passwords for more than 3 months. If the device was purchased outside this period, we cannot retrieve the password.
We do not retain credentials for extended periods due to the strict security standards we follow. While this can make recovery more difficult when a label is damaged, maintaining device security remains a top priority. We recognise that security and convenience do not always align, and we are working to improve this balance where possible.
If you purchased the device directly from us recently, please contact your sales manager to check whether the password is still available. If you purchased it from a reseller, they may have a record of it.
If the default password cannot be recovered and access to the device is no longer possible, please initiate an RMA request through your distributor. This allows the issue to be assessed securely and in line with our internal procedures. For devices purchased directly from Teltonika, please contact your sales manager. Further information is available here:
RMA process.
For future deployments, we recommend securely saving the device passwords beforehand. When purchasing directly from us, you can request a file containing device details, including passwords, at the time of purchase.
T.
