Loss of mobile connection
Hello all.
i have an TRB500
it constantly disconnect from the mobile network.?
it switches all the time from good to bad connection in the /status/network.
i have an outdoor antenna which is pointed towards the nearest mast.
The problem has not always been there and it just keeping getting worse and worse.
it look like it have an really unstable connection to mobile network.
i have an mobile phone from the same provider, and when i go outside to test the speed and connection, nothing is wrong. my phone getting 200mbs or more on the same network.
så what could be the problem? i have tried everything i my power to solve it. but no luck yet…:frowning:
i have updated the firmware, restartet, trying different settings, but no. nothing helps…
something must be wrong with the unit…
Please help me!!!
SYSTEM LOG
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] Linux version 4.14.336 (app@runner-ffjpezdj-project-352-concurrent-1) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16279-5cc0535800), GNU ld (GNU Binutils) 2.34) #0 PREEMPT Mon Apr 15 10:52:22 2024
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] CPU: div instructions available: patching division code
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] OF: fdt: Machine model: Teltonika TRB5XX
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] earlycon: msm_serial_dm0 at MMIO 0x00831000 (options ‘’)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] bootconsole [msm_serial_dm0] enabled
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Memory policy: Data cache writeback
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Reserved memory: created DMA memory pool at 0x8f800000, size 4 MiB
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] OF: reserved mem: initialized node audio_region@0, compatible id shared-dma-pool
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Reserved memory: created CMA memory pool at 0x8e800000, size 4 MiB
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] OF: reserved mem: initialized node qseecom_ta_region@0, compatible id shared-dma-pool
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Reserved memory: created CMA memory pool at 0x8d400000, size 20 MiB
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] OF: reserved mem: initialized node qseecom_region@0, compatible id shared-dma-pool
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Reserved memory: created CMA memory pool at 0x8d000000, size 4 MiB
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] OF: reserved mem: initialized node mem_dump_region, compatible id shared-dma-pool
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Removed memory: created DMA memory pool at 0x90800000, size 248 MiB
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] OF: reserved mem: initialized node mpss_adsp_region@90800000, compatible id removed-dma-pool
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] cma: Reserved 12 MiB at 0x8c400000
Thu May 2 08:41:12 2024 kern.debug kernel: [ 0.000000] On node 0 totalpages: 62254
Thu May 2 08:41:12 2024 kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat c10b6f24, node_mem_map d0593000
Thu May 2 08:41:12 2024 kern.debug kernel: [ 0.000000] Normal zone: 594 pages used for memmap
Thu May 2 08:41:12 2024 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Thu May 2 08:41:12 2024 kern.debug kernel: [ 0.000000] Normal zone: 62254 pages, LIFO batch:15
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] psci: probing for conduit method from DT.
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] psci: PSCIv1.1 detected in firmware.
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] psci: SMC Calling Convention v1.1
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] CPU: All CPU(s) started in SVC mode.
Thu May 2 08:41:12 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
Thu May 2 08:41:12 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 61660
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] Kernel command line: noinitrd ro rootwait console=ttyMSM0,115200,n8 earlycon androidboot.hardware=qcom msm_rtb.filter=0x237 loglevel=10 androidboot.console=ttyMSM0 lpm_levels.sleep_disabled=1 firmware_class.path=/lib/firmware/updates service_locator.enable=1 net.ifnames=0 atlantic_fwd.rx_ring_size=1024 pci=pcie_bus_perf ubi.mtd=rootfs_b ubi.block=0,0 root=/dev/ubiblock0_0 rootfstype=squashfs ubi.mtd=modem ubi.block=1,0 ubi.mtd=storage debug=1 androidboot.serialno=7ca35d33 androidboot.baseband=msm data_interface=[0,0] ql_pcie_mode=0
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.000000] init_pcie_mode: pcie_mode =0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Memory: 187584K/249016K available (10240K kernel code, 960K rwdata, 2880K rodata, 1024K init, 707K bss, 20472K reserved, 40960K cma-reserved, 0K highmem)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] Virtual kernel memory layout:
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] vmalloc : 0xd1000000 - 0xff800000 ( 744 MB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] lowmem : 0xc0000000 - 0xd0800000 ( 264 MB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] .text : 0xc0008000 - 0xc0b00000 (11232 kB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] .init : 0xc0f00000 - 0xc1000000 (1024 kB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] .data : 0xc1000000 - 0xc10f010c ( 961 kB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.000000] .bss : 0xc10f55b8 - 0xc11a64c4 ( 708 kB)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Preemptible hierarchical RCU implementation.
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] Tasks RCU enabled.
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.000000] arch_sys_timer depends on broadcast, but no broadcast function available
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] arch_timer: cp15 and mmio timer(s) running at 19.20MHz (virt/virt).
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.010752] Switching to timer-based delay loop, resolution 52ns
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.018740] clocksource: Switched to clocksource arch_sys_counter
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.026107] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.031005] CPU: Testing write buffer coherency: ok
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.041234] pid_max: default: 32768 minimum: 301
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.046428] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.050878] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.058909] Setting up static identity map for 0x80100000 - 0x80100060
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.064621] Hierarchical SRCU implementation.
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.078233] MSM Memory Dump base table set up
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.078300] MSM Memory Dump apps data table set up
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.119577] Duplicate name in mnfinfo, renamed to “name#1”
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.121111] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.124279] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.131644] futex hash table entries: 256 (order: 0, 7168 bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.143098] pinctrl core: initialized pinctrl subsystem
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.149187] NET: Registered protocol family 16
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.154124] DMA: preallocated 256 KiB pool for atomic coherent allocations
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.158114] cpuidle: using governor menu
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.163976] cpuidle: using governor qcom
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.168209] NET: Registered protocol family 42
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.177520] sd_vdd: regulator get failed, ret=-517
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.179875] unable to find DT imem DLOAD mode node
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.182011] unable to find DT imem EDLOAD mode node
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.186756] unable to find DT imem dload-type node
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.191973] msm_watchdog 17817000.qcom,wdt: wdog absent resource not present
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.195669] msm_watchdog 17817000.qcom,wdt: msm_wdog_dt_to_pdata scandump sizes property not correct
Thu May 2 08:41:12 2024 kern.err kernel: [ 0.203166] msm_watchdog 17817000.qcom,wdt: Couldn’t get memory for dump
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.212087] msm_watchdog 17817000.qcom,wdt: MSM Watchdog Initialized
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.220840] platform 4080000.qcom,mss: assigned reserved memory node mpss_adsp_region@90800000
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.228690] platform soc:mem_dump: assigned reserved memory node mem_dump_region
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.238429] platform 90000000.qseecom: assigned reserved memory node qseecom_region@0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.248059] platform soc:qcom,msm-audio-ion: assigned reserved memory node audio_region@0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.255224] No ATAGs?
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.263334] spmi spmi-0: PMIC arbiter version v5 (0x50010000)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.269886] sps:sps is ready.
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.271983] exit: IPA_USB init success!
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.280316] pmxprairie_s5_level: supplied by pmxprairie_s7_level
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.280721] pmxprairie_s5_level_ao: supplied by pmxprairie_s7_level_ao
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.307393] qmp-aop-clk soc:qcom,aop: Registered clocks with AOP
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.308354] clk-rpmh soc:qcom,rpmh: Registered RPMh clocks
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.313588] KPI: Bootloader start count = 76014
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.317775] KPI: Bootloader end count = 127533
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.322415] KPI: Bootloader display count = 1166295057
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.326717] KPI: Bootloader load kernel count = 15276
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.331860] KPI: Kernel MPM timestamp = 153555
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.336957] KPI: Kernel MPM Clock frequency = 32768
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.341327] socinfo_print: v0.15, id=357, ver=2.0, raw_id=207, raw_ver=2, hw_plat=8, hw_plat_ver=65536
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.341327] accessory_chip=0, hw_plat_subtype=5, pmic_model=65569, pmic_die_revision=131072 foundry_id=1 serial_number=2091081011 num_pmics=2 chip_family=0x5e raw_device_family=0x6 raw_device_number=0xb nproduct_id=0x410 num_clusters=0x1 ncluster_array_offset=0xb0 num_defective_parts=0xd ndefective_parts_array_offset=0xb4 nmodem_supported=0xffffffff
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.364484] msm_bus_fabric_rpmh_init_driver
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.386755] msm_bus: Probe started
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.387569] msm_bus_device 1100000.ad-hoc-bus: Bus type is missing
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.394028] msm_bus_device 1100000.ad-hoc-bus: Bus type is missing
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.402897] msm_bus: DT Parsing complete
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.405370] msm_bus_fab_init_noc_ops: Invalid Bus type
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.406526] msm_bus_fab_init_noc_ops: Invalid Bus type
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.425932] register_client_adhoc:find path.src 53 dest 585
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.426370] arm-smmu 15000000.apps-smmu: non-coherent table walk
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.435451] arm-smmu 15000000.apps-smmu: (IDR0.CTTW overridden by FW configuration)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 0.441727] arm-smmu 15000000.apps-smmu: stream matching with 20 register groups
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.450412] register_client_adhoc:find path.src 53 dest 585
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.451023] register_client_adhoc:find path.src 53 dest 585
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.457782] vgaarb: loaded
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.468168] usbcore: registered new interface driver usbfs
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.470703] usbcore: registered new interface driver hub
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.476110] usbcore: registered new device driver usb
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.482012] usb_phy_generic soc:usb_nop_phy: soc:usb_nop_phy supply vcc not found, using dummy regulator
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.487445] qcom,qpnp-power-on c440000.qcom,spmi:qcom,pmxprairie@8:qcom,power-on@800: PMIC@SID8 Power-on reason: Triggered from Hard Reset and ‘cold’ boot
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.496154] qcom,qpnp-power-on c440000.qcom,spmi:qcom,pmxprairie@8:qcom,power-on@800: PMIC@SID8: Power-off reason: Triggered from PS_HOLD (PS_HOLD/MSM Controlled Shutdown)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.509997] input: qpnp_pon as /devices/platform/c440000.qcom,spmi/spmi-0/spmi0-08/c440000.qcom,spmi:qcom,pmxprairie@8:qcom,power-on@800/input/input0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.539346] platform soc:qcom,ion:qcom,ion-heap@27: assigned reserved memory node qseecom_region@0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.539576] platform soc:qcom,ion:qcom,ion-heap@19: assigned reserved memory node qseecom_ta_region@0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.547414] platform soc:qcom,ion:qcom,ion-heap@28: assigned reserved memory node audio_region@0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.556911] ION heap system created
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.565643] ION heap qsecom created at 0x8d400000 with size 1400000
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.568613] ION heap qsecom_ta created at 0x8e800000 with size 400000
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.574907] ION heap audio created at 0x8f800000 with size 400000
Thu May 2 08:41:12 2024 kern.err kernel: [ 0.583549] scm_call failed: func id 0x2000c10, ret: -1, syscall returns: 0x0, 0x0, 0x0
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.587544] ipa ipa3_tz_unlock_reg:6958 scm call SCM_SVC_MP failed: -5
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.595421] ipa ipa3_pre_init:7215 Failed to unlock memory region using TZ
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.602236] register_client_adhoc:find path.src 90 dest 774
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.602397] register_client_adhoc:find path.src 134 dest 512
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.609002] register_client_adhoc:find path.src 90 dest 585
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.614422] register_client_adhoc:find path.src 1 dest 676
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.620377] register_client_adhoc:find path.src 143 dest 777
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.630435] iommu: Adding device 1e00000.qcom,ipa:ipa_smmu_ap to group 0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.637654] iommu: Adding device 1e00000.qcom,ipa:ipa_smmu_wlan to group 1
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.644393] iommu: Adding device 1e00000.qcom,ipa:ipa_smmu_uc to group 2
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.650415] gsi_is_mcs_enabled:1032 MCS enabled:1
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.657117] Using XBL boot load for IPA FW
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.661784] ipa ipa_smmu_ap_cb_probe:8784 AP Geometry start = 0 size= f0000000
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.665752] IPA smmu_info.s1_bypass_arr[AP]=0 smmu_info.fast_map=1
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.684610] IPA smmu_info.s1_bypass_arr[WLAN]=0 smmu_info.fast_map=0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.685265] IPA smmu_info.s1_bypass_arr[UC]=0 smmu_info.fast_map=0
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.691370] ipa ipa3_uc_state_check:377 uC interface not initialized
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.709577] IPA driver initialization was successful.
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.710490] ipa ipa3_smp2p_probe:8954 fail to get smp2p clk resp bit -517
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.715014] ipa ipa3_smp2p_probe:8954 fail to get smp2p clk resp bit -517
Thu May 2 08:41:12 2024 kern.alert kernel: [ 0.723456] pcie:pcie_init.
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.732720] pci-msm: probe of 1c00000.qcom,pcie failed with error -1
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.734633] qcom-cpu-sdxprairie 17810008.qcom,clock-cpu: No speed/PVS binning available. Defaulting to 0!
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.739440] Clock_cpu:(cpu 0) OPP voltage for 345600000: 65
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.747704] Clock_cpu:(cpu 0) OPP voltage for 1555200000: 385
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.753177] qcom-cpu-sdxprairie 17810008.qcom,clock-cpu: CPU clock Driver probed successfully
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.761673] gcc-sdxprairie 100000.qcom,gcc: Registered GCC clocks
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.769658] cpufreq: driver msm up and running
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.773876] ipa ipa3_smp2p_probe:8954 fail to get smp2p clk resp bit -517
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.778930] clocksource: Switched to clocksource arch_sys_counter
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.838415] NET: Registered protocol family 2
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.838886] IP idents hash table entries: 4096 (order: 3, 32768 bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.842778] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.848325] TCP bind hash table entries: 2048 (order: 3, 40960 bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.855261] TCP: Hash tables configured (established 2048 bind 2048)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.861945] UDP hash table entries: 256 (order: 1, 12288 bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.868175] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.874240] NET: Registered protocol family 1
Thu May 2 08:41:12 2024 kern.debug kernel: [ 0.880461] PCI: CLS 0 bytes, default 64
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.885056] ipa ipa3_smp2p_probe:8954 fail to get smp2p clk resp bit -517
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.891937] workingset: timestamp_bits=13 max_order=16 bucket_order=3
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.902335] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.909990] io scheduler noop registered
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.910094] io scheduler deadline registered
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.913486] io scheduler cfq registered (default)
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.917333] io scheduler mq-deadline registered
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.922101] io scheduler kyber registered
Thu May 2 08:41:12 2024 kern.err kernel: [ 0.934971] qcom-sps-dma 804000.qcom,sps-dma: dma_async_device_register: device has no channels!
Thu May 2 08:41:12 2024 kern.warn kernel: [ 0.938097] qcom_smp2p: probe of 17811008.qcom,smp2p-modem failed with error -22
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.943953] register_client_adhoc:find path.src 125 dest 512
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.944771] subsys-pil-tz 4080000.qcom,mss: for modem segments only will be dumped.
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.957305] subsys-pil-tz soc:qcom,ipa_fws: for ipa_fws segments only will be dumped.
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.972344] msm_serial 831000.serial: msm_serial: detected port #0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.972515] msm_serial 831000.serial: uartclk = 1843200
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.977599] 831000.serial: ttyMSM0 at MMIO 0x831000 (irq = 25, base_baud = 115200) is a MSM
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.982895] msm_serial: console setup on port #0
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.991343] console [ttyMSM0] enabled
Thu May 2 08:41:12 2024 kern.info kernel: [ 0.994040] bootconsole [msm_serial_dm0] disabled
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.003412] msm_serial: driver initialized
Thu May 2 08:41:12 2024 kern.warn kernel: [ 1.008461] got reovery_uart4a normal system skip
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.012226] register_client_adhoc:find path.src 1 dest 618
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.014899] random: crng init done
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.023093] diag: Pcie registration initiated for id: 0
Thu May 2 08:41:12 2024 kern.err kernel: [ 1.024894] diag: diag_pcie_register: failed registering pcie channels
Thu May 2 08:41:12 2024 kern.err kernel: [ 1.030029] diag: MUX: unable to register pcie operations for proc: 0, err: -22
Thu May 2 08:41:12 2024 kern.err kernel: [ 1.036367] diag: MUX: unable to register PCIe operations, continuing with USB registrations for proc: 0, err: -22
Thu May 2 08:41:12 2024 kern.err kernel: [ 1.051437] diag: Unable to register with PCIE, id: 1
Thu May 2 08:41:12 2024 kern.err kernel: [ 1.053960] diag: MUX: unable to register pcie operations for proc: 1, err: -5
Thu May 2 08:41:12 2024 kern.err kernel: [ 1.059978] diag: MUX: unable to register PCIe operations, continuing with USB registrations for proc: 1, err: -5
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.075575] brd: module loaded
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.082605] loop: module loaded
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.083112] zram: Added device: zram0
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.085420] QSEECOM: qseecom_probe: qseecom.qsee_version = 0x1402000
Thu May 2 08:41:12 2024 kern.warn kernel: [ 1.088500] QSEECOM: qseecom_retrieve_ce_data: Device does not support PFE/FDE
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.088511] QSEECOM: qseecom_probe: no-clock-support=0x1
Thu May 2 08:41:12 2024 kern.warn kernel: [ 1.095184] QSEECOM: qseecom_probe: qseecom.qsee_reentrancy_support = 2
Thu May 2 08:41:12 2024 kern.warn kernel: [ 1.107475] QSEECOM: qseecom_probe: secure app region addr=0x90000000 size=0x500000
Thu May 2 08:41:12 2024 kern.warn kernel: [ 1.110243] QSEECOM: qseecom_probe: qseecom.whitelist_support = 1
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.123728] register_client_adhoc:find path.src 91 dest 512
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.125360] sps: BAM device 0x01b04000 is not registered yet.
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.133522] sps:BAM 0x01b04000 is registered.
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.133538] msm_nand_bam_init: msm_nand_bam_init: BAM device registered: bam_handle 0xca432200
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.143652] sps:BAM 0x01b04000 (va:0xd1820000) enabled: ver:0x19, number of pipes:9
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.152333] msm_nand_version_check: nand_major:2, nand_minor:0, qpic_major:2, qpic_minor:0
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.159537] msm_nand_parse_smem_ptable: Parsing partition table info from SMEM
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.167764] msm_nand_parse_smem_ptable: SMEM partition table found: ver: 4 len: 26
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.174890] msm_nand_version_check: nand_major:2, nand_minor:0, qpic_major:2, qpic_minor:0
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.182467] msm_nand_flash_onfi_probe: msm_nand_flash_onfi_probe: no apps partition found in smem
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.190717] msm_nand_scan: NAND Id: 0x2680ac2c Buswidth: 8Bits Density: 512 MByte
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.199579] msm_nand_scan: pagesize: 4096 Erasesize: 262144 oobsize: 256 (in Bytes)
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.207028] msm_nand_scan: BCH ECC: 8 Bit
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.214489] msm_nand_scan: CFG0: 0x290409c0, CFG1: 0x08045d5c
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.214489] RAWCFG0: 0x2b8401c0, RAWCFG1: 0x0005055d
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.214489] ECCBUFCFG: 0x00000203, ECCBCHCFG: 0x42040d10
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.214489] RAWECCCFG: 0x42000d11, BAD BLOCK BYTE: 0x00000175
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.222614] Creating 26 MTD partitions on “1b00000.nand”:
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.244890] 0x000000000000-0x000000280000 : “sbl”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.251350] 0x000000280000-0x000000380000 : “mibib”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.255709] 0x000000380000-0x000001980000 : “efs2”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.260442] 0x000001980000-0x000001c00000 : “rawdata”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.265263] 0x000001c00000-0x000001f80000 : “sys_rev”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.270489] 0x000001f80000-0x000002200000 : “cust_info”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.275404] 0x000002200000-0x000002400000 : “tz”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.280507] 0x000002400000-0x000002540000 : “tz_devcfg”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.285277] 0x000002540000-0x000002680000 : “ddr”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.290306] 0x000002680000-0x0000027c0000 : “apdp”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.295098] 0x0000027c0000-0x000002900000 : “xbl_config”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.299895] 0x000002900000-0x000002a40000 : “aop”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.305254] 0x000002a40000-0x000002b80000 : “qhee”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.309960] 0x000002b80000-0x000002cc0000 : “abl”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.314519] 0x000002cc0000-0x000002f40000 : “uefi”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.319404] 0x000002f40000-0x000003080000 : “mnf_info”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.324015] 0x000003080000-0x0000031c0000 : “boot_config”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.329240] 0x0000031c0000-0x000003fc0000 : “boot_a”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.334812] 0x000003fc0000-0x000004dc0000 : “boot_b”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.339780] 0x000004dc0000-0x000004f00000 : “misc”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.344565] 0x000004f00000-0x00000c000000 : “modem”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.349317] 0x00000c000000-0x00000c140000 : “ipa_fw”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.353965] 0x00000c140000-0x00000c280000 : “usb_qti”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.359325] 0x00000c280000-0x000014380000 : “rootfs_a”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.364160] 0x000014380000-0x00001c480000 : “rootfs_b”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.369237] 0x00001c480000-0x000020000000 : “storage”
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.374281] msm_nand_probe: NANDc phys addr 0x1b00000, BAM phys addr 0x1b04000, BAM IRQ 34
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.378898] msm_nand_probe: Allocated DMA buffer at virt_addr 0xcc440000, phys_addr 0x8c440000
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.386984] msm_nand_probe: Host capabilities:0x00000000
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.404325] MNFINFO PROPERTIES:
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.404391] mac : 20972713387F
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.406314] name : TRB50000XXXX
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.410248] serial : 6001003096
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.413688] hwver : 0004
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.416897] branch :
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.419949] batch : 0012
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.422451] sim_count: 1
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.426062] MACsec IEEE 802.1AE
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.428913] tun: Universal TUN/TAP device driver, 1.6
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.430930] PPP generic driver version 2.4.2
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.436197] usbcore: registered new interface driver asix
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.440545] usbcore: registered new interface driver ax88179_178a
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.445687] usbcore: registered new interface driver cdc_ether
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.451806] usbcore: registered new interface driver smsc75xx
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.457493] usbcore: registered new interface driver smsc95xx
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.463347] usbcore: registered new interface driver net1080
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.469053] usbcore: registered new interface driver cdc_subset
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.474760] usbcore: registered new interface driver zaurus
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.481009] usbcore: registered new interface driver cdc_ncm
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.489486] sd_vdd: supplied by vddpx_2
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.493888] iommu: Adding device a600000.ssusb to group 3
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.498098] dwc3 a600000.dwc3: changing max_speed on rev 00000000
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.505349] register_client_adhoc:find path.src 61 dest 512
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.505866] register_client_adhoc:find path.src 61 dest 676
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.507232] register_client_adhoc:find path.src 1 dest 583
Thu May 2 08:41:12 2024 kern.warn kernel: [ 1.514113] Invalid index Defaulting curr to 0
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.524473] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.528005] ehci-pci: EHCI PCI platform driver
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.536038] usbcore: registered new interface driver cdc_acm
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.539705] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.544856] usbcore: registered new interface driver usb_ehset_test
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.552583] usbcore: registered new interface driver lvs
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.560320] udc-core: couldn’t find an available UDC - added [g_ether] to list of pending drivers
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.565534] i2c /dev entries driver
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.574083] register_client_adhoc:find path.src 86 dest 512
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.587907] usbcore: registered new interface driver usbhid
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.592964] tz_log 1468f720.tz-log: Hyp log service is not supported
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.599357] usbhid: USB HID core driver
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.605900] ipa_ut ipa_ut_module_init:1045 Loading IPA test module…
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.609857] register_client_adhoc:find path.src 1 dest 627
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.611167] register_client_adhoc:find path.src 1 dest 512
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.616260] register_client_adhoc:find path.src 1 dest 512
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.624933] Netfilter messages via NETLINK v0.30.
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.631164] nf_conntrack version 0.5.0 (4096 buckets, 16384 max)
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.635821] ctnetlink v0.93: registering with nfnetlink.
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.642047] ip_set: protocol 6
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.647171] ipip: IPv4 and MPLS over IPv4 tunneling driver
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.650479] ip_tables: (C) 2000-2006 Netfilter Core Team
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.655744] arp_tables: arp_tables: (C) 2002 David S. Miller
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.661351] NET: Registered protocol family 10
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.667390] Segment Routing with IPv6
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.670904] ip6_tables: (C) 2000-2006 Netfilter Core Team
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.674894] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.680377] NET: Registered protocol family 17
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.685660] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.690217] Ebtables v2.0 registered
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.703443] 8021q: 802.1Q VLAN Support v1.8
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.709288] dwc3 a600000.dwc3: changing max_speed on rev 00000000
Thu May 2 08:41:12 2024 kern.warn kernel: [ 1.711179] using random self ethernet address
Thu May 2 08:41:12 2024 kern.warn kernel: [ 1.716959] using random host ethernet address
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.721862] ecm0: HOST MAC b6:52:db:16:62:34
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.725726] ecm0: MAC c2:f5:a6:44:fb:8e
Thu May 2 08:41:12 2024 kern.warn kernel: [ 1.730247] using random self ethernet address
Thu May 2 08:41:12 2024 kern.warn kernel: [ 1.733711] using random host ethernet address
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.738296] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.742723] g_ether gadget: g_ether ready
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.751921] register_client_adhoc:find path.src 61 dest 512
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.752312] register_client_adhoc:find path.src 61 dest 676
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.753507] register_client_adhoc:find path.src 1 dest 583
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.758848] usb_bam_init: setting SPS_BAM_SMMU_EN flag with (a704000.qcom,usbbam)
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.770603] sps:BAM 0x0a704000 is registered.
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.788882] ubi0: attaching mtd24
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.829021] msm-dwc3 a600000.ssusb: DWC3 exited from low power mode
Thu May 2 08:41:12 2024 kern.info kernel: [ 1.829860] msm-dwc3 a600000.ssusb: DWC3 in low power mode
Thu May 2 08:41:12 2024 kern.err kernel: [ 1.838789] msm-dwc3 a600000.ssusb: Could not get usb psy
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.919071] ubi0: scanning is finished
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.924539] ubi0: attached mtd24 (name “rootfs_b”, size 129 MiB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.924580] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.929669] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.936306] ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.943176] ubi0: good PEBs: 516, bad PEBs: 0, corrupted PEBs: 0
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.949944] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.956187] ubi0: max/mean erase counter: 4/2, WL threshold: 4096, image sequence number: 670962332
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.963234] ubi0: available PEBs: 0, total reserved PEBs: 516, PEBs reserved for bad PEB handling: 40
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.972184] ubi0: background thread “ubi_bgt0d” started, PID 183
Thu May 2 08:41:12 2024 kern.notice kernel: [ 1.981565] ubi1: attaching mtd20
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.091362] ubi1: scanning is finished
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.096731] ubi1: attached mtd20 (name “modem”, size 113 MiB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.096771] ubi1: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.101511] ubi1: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.108239] ubi1: VID header offset: 4096 (aligned 4096), data offset: 8192
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.115109] ubi1: good PEBs: 452, bad PEBs: 0, corrupted PEBs: 0
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.121876] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.128118] ubi1: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 780157798
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.135168] ubi1: available PEBs: 0, total reserved PEBs: 452, PEBs reserved for bad PEB handling: 40
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.144115] ubi1: background thread “ubi_bgt1d” started, PID 184
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.153495] ubi2: attaching mtd25
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.214833] ubi2: scanning is finished
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.219993] ubi2: attached mtd25 (name “storage”, size 59 MiB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.220032] ubi2: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.224728] ubi2: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.231626] ubi2: VID header offset: 4096 (aligned 4096), data offset: 8192
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.238444] ubi2: good PEBs: 238, bad PEBs: 0, corrupted PEBs: 0
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.245225] ubi2: user volume: 1, internal volumes: 1, max. volumes count: 128
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.251476] ubi2: max/mean erase counter: 5/2, WL threshold: 4096, image sequence number: 18592848
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.258505] ubi2: available PEBs: 0, total reserved PEBs: 238, PEBs reserved for bad PEB handling: 40
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.267461] ubi2: background thread “ubi_bgt2d” started, PID 185
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.277669] block ubiblock0_0: created from ubi0:0(rootfs)
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.283825] block ubiblock1_0: created from ubi1:0(modem)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.288997] cpuidle: enable-method property ‘psci’ found operations
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.294056] lpm_levels: register_cluster_lpm_stats()
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.300980] rmnet_ipa3 started initialization
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.304844] IPA SSR support = True
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.309136] IPA is_platform_type_msm = False
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.312392] IPA SG support = False
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.316816] IPA Napi Enable = False
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.320041] using default for wan-rx-desc-size = 256
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.325152] ipa-wan ipa3_wwan_probe:2963 rmnet_ipa completed initialization
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.329586] RNDIS_IPA module is loaded.
Thu May 2 08:41:12 2024 kern.warn kernel: [ 2.329595] @Ramos Qstart_init entry !!!
Thu May 2 08:41:12 2024 kern.err kernel: [ 2.339733] msm_bus_late_init: Remove handoff bw requests
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.343837] emac_phy: disabling
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.348706] rgmii_io_pads: disabling
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.351666] rgmii_io_pads: disabling
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.355461] vddpx_2: disabling
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.359029] vreg_conn_pa: disabling
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.365413] VFS: Mounted root (squashfs filesystem) readonly on device 253:0.
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.366799] Freeing unused kernel memory: 1024K
Thu May 2 08:41:12 2024 kern.warn kernel: [ 2.374726] [modem_cfg] open /data/modem_cfg fail ret is -2
Thu May 2 08:41:12 2024 kern.warn kernel: [ 2.375905] [modem_cfg] read_buf A00101A10101A20101A30101A40101A50101A60101A70101A80101A90101AB0101MQ
Thu May 2 08:41:12 2024 kern.warn kernel: [ 2.381883] [modem_cfg] smem copy length=69
Thu May 2 08:41:12 2024 kern.warn kernel: [ 2.391021] [modem_cfg] smem alloc sucessfully
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.395338] @quectelKernel command line: noinitrd ro rootwait console=ttyMSM0,115200,n8 earlycon androidboot.hardware=qcom msm_rtb.filter=0x237 loglevel=10 androidboot.console=ttyMSM0 lpm_levels.sleep_disabled=1 firmware_class.path=/lib/firmware/updates service_locator.enable=1 net.ifnames=0 atlantic_fwd.rx_ring_size=1024 pci=pcie_bus_perf ubi.mtd=rootfs_b ubi.block=0,0 root=/dev/ubiblock0_0 rootfstype=squashfs ubi.mtd=modem ubi.block=1,0 ubi.mtd=storage debug=1 androidboot.serialno=7ca35d33 androidboot.baseband=msm data_interface=[0,0] ql_pcie_mode=0
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.519364] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name “modem”, R/O mode
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.519418] UBIFS (ubi1:0): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.526550] UBIFS (ubi1:0): FS size: 101072896 bytes (96 MiB, 398 LEBs), journal size 9404416 bytes (8 MiB, 38 LEBs)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.536477] UBIFS (ubi1:0): reserved for root: 0 bytes (0 KiB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 2.547032] UBIFS (ubi1:0): media format: w4/r0 (latest is w5/r0), UUID EB32DB54-1FCD-481C-911F-100028C78921, small LPT model
Thu May 2 08:41:12 2024 user.info kernel: [ 2.702606] init: Console is alive
Thu May 2 08:41:12 2024 user.info kernel: [ 2.954250] kmodloader: loading kernel modules from /etc/modules-boot.d/
Thu May 2 08:41:12 2024 kern.warn kernel: [ 2.967470] emac_dwc_eqos: loading out-of-tree module taints kernel.
Thu May 2 08:41:12 2024 kern.info kernel: [ 2.975482] qcom-emac-dwc-eqos DWC_ETH_QOS_get_dts_config:1115 phy_addr = 0
Thu May 2 08:41:12 2024 kern.info kernel: [ 3.057885] iommu: Adding device 20000.qcom,emac:emac_emb_smmu to group 4
Thu May 2 08:41:12 2024 kern.info kernel: [ 3.060102] register_client_adhoc:find path.src 98 dest 512
Thu May 2 08:41:12 2024 kern.info kernel: [ 3.060470] register_client_adhoc:find path.src 1 dest 781
Thu May 2 08:41:12 2024 kern.info kernel: [ 3.065397] qcom-emac-dwc-eqos DWC_ETH_QOS_configure_netdevice:2168 ipa_tx_desc_cnt_mod_param = 128
Thu May 2 08:41:12 2024 kern.info kernel: [ 3.074649] qcom-emac-dwc-eqos DWC_ETH_QOS_configure_netdevice:2170 ipa_rx_desc_cnt_mod_param = 128
Thu May 2 08:41:12 2024 kern.info kernel: [ 3.084090] qcom-emac-dwc-eqos DWC_ETH_QOS_mdio_register:1244 skip_phy_detection (phyaddr)0
Thu May 2 08:41:12 2024 kern.info kernel: [ 3.113549] qcom-emac-dwc-eqos 20000.qcom,emac (unnamed net_device) (uninitialized): yt8521 hw strap config mode=0, chip idx=0.
Thu May 2 08:41:12 2024 kern.info kernel: [ 3.118583] qcom-emac-dwc-eqos 20000.qcom,emac (unnamed net_device) (uninitialized): yt8521 config init done, strap mode=0, polling mode=2.
Thu May 2 08:41:12 2024 kern.warn kernel: [ 3.128668] netif_napi_add() called with weight 256 on device eth%d
Thu May 2 08:41:12 2024 kern.warn kernel: [ 3.136439] netif_napi_add() called with weight 256 on device eth%d
Thu May 2 08:41:12 2024 kern.warn kernel: [ 3.142634] netif_napi_add() called with weight 256 on device eth%d
Thu May 2 08:41:12 2024 kern.info kernel: [ 3.149700] qcom-emac-dwc-eqos DWC_ETH_QOS_update_rgmii_tx_drv_strength:1216 IOMACRO pads voltage: 1800000 uV
Thu May 2 08:41:12 2024 user.info kernel: [ 3.160298] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Thu May 2 08:41:12 2024 user.info kernel: [ 3.169478] init: - preinit -
Thu May 2 08:41:12 2024 kern.notice kernel: [ 3.948862] UBIFS (ubi0:1): background thread “ubifs_bgt0_1” started, PID 330
Thu May 2 08:41:12 2024 kern.notice kernel: [ 3.988424] UBIFS (ubi0:1): recovery needed
Thu May 2 08:41:12 2024 kern.notice kernel: [ 4.085313] UBIFS (ubi0:1): recovery completed
Thu May 2 08:41:12 2024 kern.notice kernel: [ 4.085432] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name “rootfs_data”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 4.088669] UBIFS (ubi0:1): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
Thu May 2 08:41:12 2024 kern.notice kernel: [ 4.096626] UBIFS (ubi0:1): FS size: 104374272 bytes (99 MiB, 411 LEBs), journal size 5332992 bytes (5 MiB, 21 LEBs)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 4.106517] UBIFS (ubi0:1): reserved for root: 4929854 bytes (4814 KiB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 4.117063] UBIFS (ubi0:1): media format: w5/r0 (latest is w5/r0), UUID 0537C0F9-C73C-4C3C-AF26-5EB58D6D2584, small LPT model
Thu May 2 08:41:12 2024 user.info kernel: [ 4.127905] mount_root: switching to ubifs overlay
Thu May 2 08:41:12 2024 user.warn kernel: [ 4.146954] urandom-seed: Seeding with /etc/urandom.seed
Thu May 2 08:41:12 2024 user.warn kernel: [ 4.171970] - preparing events-log partition -
Thu May 2 08:41:12 2024 kern.info kernel: [ 4.180104] qcom-emac-dwc-eqos 20000.qcom,emac eth0: yt8521, link down.
Thu May 2 08:41:12 2024 user.info kernel: [ 4.206991] procd: - early -
Thu May 2 08:41:12 2024 user.info kernel: [ 4.877803] procd: - ubus -
Thu May 2 08:41:12 2024 user.info kernel: [ 4.934073] procd: - init -
Thu May 2 08:41:12 2024 user.info kernel: [ 6.167396] urngd: v1.0.2 started.
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.260048] qcom-emac-dwc-eqos 20000.qcom,emac eth0: yt8521, link up, UTP, reg 0x11=0xbc00.
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.260105] qcom-emac-dwc-eqos 20000.qcom,emac eth0: yt8521, link up, media UTP, reg 0x11=0xbc00.
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.297646] qcom-emac-dwc-eqos 20000.qcom,emac eth0: Link is Up - 1Gbps/Full - flow control off
Thu May 2 08:41:12 2024 kern.notice kernel: [ 6.348803] UBIFS (ubi2:0): background thread “ubifs_bgt2_0” started, PID 518
Thu May 2 08:41:12 2024 user.info kernel: [ 6.457097] kmodloader: loading kernel modules from /etc/modules.d/*
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.516333] NET: Registered protocol family 15
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.530430] Initializing XFRM netlink socket
Thu May 2 08:41:12 2024 kern.warn kernel: [ 6.584069] ipa ipa3_uc_state_check:382 uC is not loaded
Thu May 2 08:41:12 2024 kern.warn kernel: [ 6.589289] ipa ipa3_uc_state_check:382 uC is not loaded
Thu May 2 08:41:12 2024 kern.warn kernel: [ 6.590038] ipa ipa3_uc_state_check:382 uC is not loaded
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.611716] l2tp_core: L2TP core driver, V2.0
Thu May 2 08:41:12 2024 kern.warn kernel: [ 6.612373] ipa ipa3_uc_state_check:382 uC is not loaded
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.617516] l2tp_netlink: L2TP netlink interface
Thu May 2 08:41:12 2024 kern.warn kernel: [ 6.629358] ipa ipa3_uc_state_check:382 uC is not loaded
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.632173] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.645059] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.655809] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.684632] gre: GRE over IPv4 demultiplexor driver
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.686453] ip_gre: GRE over IPv4 tunneling driver
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.707887] ip6_gre: GRE over IPv6 tunneling driver
Thu May 2 08:41:12 2024 kern.notice kernel: [ 6.724507] UBIFS (ubi2:0): UBIFS: mounted UBI device 2, volume 0, name “storage”
Thu May 2 08:41:12 2024 kern.notice kernel: [ 6.724559] UBIFS (ubi2:0): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
Thu May 2 08:41:12 2024 kern.notice kernel: [ 6.800978] UBIFS (ubi2:0): FS size: 46727168 bytes (44 MiB, 184 LEBs), journal size 2285568 bytes (2 MiB, 9 LEBs)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 6.801039] UBIFS (ubi2:0): reserved for root: 2207039 bytes (2155 KiB)
Thu May 2 08:41:12 2024 kern.notice kernel: [ 6.834027] UBIFS (ubi2:0): media format: w5/r0 (latest is w5/r0), UUID BEF0AB59-2EEF-4E09-AB67-EFA0414FCD4D, small LPT model
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.897343] tlt-gpio: set names for f100000.pinctrl chip
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.898211] tlt-gpio: set names for c440000.qcom,spmi:qcom,pmxprairie@8:pinctrl@c000 chip
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.955632] usbcore: registered new interface driver cdc_wdm
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.971953] PPP MPPE Compression module registered
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.972937] NET: Registered protocol family 24
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.979906] PPTP driver version 0.8.5
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.981117] Loading modem subsystem…
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.983810] subsys-restart: __subsystem_get(): Changing subsys fw_name to modem
Thu May 2 08:41:12 2024 kern.info kernel: [ 6.987485] ipa-wan ipa3_lcl_mdm_ssr_notifier_cb:3246 IPA received MPSS BEFORE_POWERUP
Thu May 2 08:41:12 2024 kern.warn kernel: [ 7.037646] ipa ipa3_uc_state_check:382 uC is not loaded
Thu May 2 08:41:12 2024 kern.info kernel: [ 7.037688] ipa-wan ipa3_lcl_mdm_ssr_notifier_cb:3258 IPA BEFORE_POWERUP handling is complete
Thu May 2 08:41:12 2024 kern.info kernel: [ 7.062448] subsys-pil-tz 4080000.qcom,mss: modem: loading from 0x90800000 to 0xa0000000
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.279867] subsys-pil-tz 4080000.qcom,mss: modem: Brought out of reset
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.330568] subsys-pil-tz 4080000.qcom,mss: Subsystem error monitoring/handling services are up
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.330621] subsys-pil-tz 4080000.qcom,mss: modem: Power/Clock ready interrupt received
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.340322] ipa-wan ipa3_lcl_mdm_ssr_notifier_cb:3261 IPA received MPSS AFTER_POWERUP
Thu May 2 08:41:12 2024 kern.err kernel: [ 14.346055] ipa ipa3_odl_pipe_open:371 adpl pipe not configured
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.354398] qrtr: Modem QMI Readiness RX cmd:0x2 node[0x3]
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.360866] ipa-wan ipa3_lcl_mdm_ssr_notifier_cb:3267 IPA AFTER_POWERUP handling is complete
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.368008] usbcore: registered new interface driver qmi_wwan
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.378596] usbcore: registered new interface driver usbserial
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.379887] usbcore: registered new interface driver usbserial_generic
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.385472] usbserial: USB Serial support registered for generic
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.401622] xt_time: kernel timezone is -0000
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.403096] l2tp_ppp: PPPoL2TP kernel driver, V2.0
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.415320] usbcore: registered new interface driver option
Thu May 2 08:41:12 2024 kern.info kernel: [ 14.415587] usbserial: USB Serial support registered for GSM modem (1-port)
Thu May 2 08:41:12 2024 user.info kernel: [ 14.420678] kmodloader: done loading kernel modules from /etc/modules.d/*
Thu May 2 08:41:12 2024 kern.alert kernel: [ 14.980932] qcom-emac-dwc-eqos 20000.qcom,emac: State change - rxcsum enable
Thu May 2 08:41:13 2024 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Thu May 2 08:41:13 2024 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Thu May 2 08:41:13 2024 daemon.info dnsmasq[999]: started, version 2.89 cachesize 150
Thu May 2 08:41:13 2024 daemon.info dnsmasq[999]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Thu May 2 08:41:13 2024 daemon.info dnsmasq[999]: UBus support enabled: connected to system bus
Thu May 2 08:41:13 2024 daemon.info dnsmasq[999]: using only locally-known addresses for test
Thu May 2 08:41:13 2024 daemon.info dnsmasq[999]: using only locally-known addresses for onion
Thu May 2 08:41:13 2024 daemon.info dnsmasq[999]: using only locally-known addresses for localhost
Thu May 2 08:41:13 2024 daemon.info dnsmasq[999]: using only locally-known addresses for invalid
Thu May 2 08:41:13 2024 daemon.info dnsmasq[999]: using only locally-known addresses for bind
Thu May 2 08:41:13 2024 daemon.info dnsmasq[999]: using only locally-known addresses for lan
Thu May 2 08:41:13 2024 daemon.warn dnsmasq[999]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Thu May 2 08:41:13 2024 daemon.info dnsmasq[999]: read /etc/hosts - 12 names
Thu May 2 08:41:13 2024 daemon.info dnsmasq[999]: read /tmp/hosts/dhcp.cfg01411c - 0 names
Thu May 2 08:41:14 2024 user.notice : Added device handler type: bonding
Thu May 2 08:41:14 2024 user.notice : Added device handler type: 8021ad
Thu May 2 08:41:14 2024 user.notice : Added device handler type: 8021q
Thu May 2 08:41:14 2024 user.notice : Added device handler type: macvlan
Thu May 2 08:41:14 2024 user.notice : Added device handler type: veth
Thu May 2 08:41:14 2024 user.notice : Added device handler type: bridge
Thu May 2 08:41:14 2024 user.notice : Added device handler type: Network device
Thu May 2 08:41:14 2024 user.notice : Added device handler type: tunnel
Thu May 2 08:41:14 2024 kern.info kernel: [ 17.435376] IPA is loading with non MHI configuration
Thu May 2 08:41:14 2024 kern.warn kernel: [ 17.906600] ipa ipa3_uc_state_check:382 uC is not loaded
Thu May 2 08:41:14 2024 daemon.notice netifd: Interface ‘eth0’ is enabled
Thu May 2 08:41:14 2024 daemon.notice netifd: Interface ‘eth0’ is setting up now
Thu May 2 08:41:14 2024 kern.info kernel: [ 17.940220] 8021q: adding VLAN 0 to HW filter on device eth0
Thu May 2 08:41:14 2024 daemon.notice netifd: Interface ‘eth0’ is now up
Thu May 2 08:41:14 2024 kern.info kernel: [ 17.970782] br-lan: port 1(eth0) entered blocking state
Thu May 2 08:41:14 2024 kern.info kernel: [ 17.970826] br-lan: port 1(eth0) entered disabled state
Thu May 2 08:41:14 2024 kern.info kernel: [ 18.026739] device eth0 entered promiscuous mode
Thu May 2 08:41:14 2024 kern.info kernel: [ 18.039316] br-lan: port 1(eth0) entered blocking state
Thu May 2 08:41:14 2024 kern.info kernel: [ 18.039359] br-lan: port 1(eth0) entered forwarding state
Thu May 2 08:41:14 2024 daemon.notice netifd: Interface ‘lan’ is enabled
Thu May 2 08:41:14 2024 daemon.notice netifd: Interface ‘lan’ is setting up now
Thu May 2 08:41:14 2024 kern.info kernel: [ 18.074179] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Thu May 2 08:41:14 2024 daemon.notice netifd: Interface ‘lan’ is now up
Thu May 2 08:41:14 2024 kern.info kernel: [ 18.112367] br-lan: port 2(ecm0) entered blocking state
Thu May 2 08:41:14 2024 kern.info kernel: [ 18.112410] br-lan: port 2(ecm0) entered disabled state
Thu May 2 08:41:14 2024 daemon.notice netifd: bridge ‘br-lan’ link is up
Thu May 2 08:41:14 2024 daemon.notice netifd: Interface ‘lan’ has link connectivity
Thu May 2 08:41:14 2024 kern.info kernel: [ 18.158887] device ecm0 entered promiscuous mode
Thu May 2 08:41:15 2024 daemon.notice netifd: Interface ‘loopback’ is enabled
Thu May 2 08:41:15 2024 daemon.notice netifd: Interface ‘loopback’ is setting up now
Thu May 2 08:41:15 2024 daemon.notice netifd: Interface ‘loopback’ is now up
Thu May 2 08:41:15 2024 kern.info kernel: [ 18.190744] qrtr: Modem QMI Readiness TX cmd:0x2 node[0x2]
Thu May 2 08:41:15 2024 kern.err kernel: [ 18.202218] ipa-wan ipa3_handle_indication_req:152 not send indication
Thu May 2 08:41:15 2024 daemon.notice netifd: bridge ‘br-lan’ link is down
Thu May 2 08:41:15 2024 daemon.notice netifd: Interface ‘lan’ has link connectivity loss
Thu May 2 08:41:15 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Thu May 2 08:41:15 2024 daemon.notice netifd: Interface ‘eth0’ has link connectivity
Thu May 2 08:41:15 2024 kern.err kernel: [ 18.219051] diag: In diag_send_feature_mask_update, control channel is not open, p: 0, c1187348
Thu May 2 08:41:15 2024 kern.err kernel: [ 18.219654] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 0
Thu May 2 08:41:15 2024 daemon.notice netifd: bridge ‘br-lan’ link is up
Thu May 2 08:41:15 2024 kern.info kernel: [ 18.232859] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and modem’s SSCTL service
Thu May 2 08:41:15 2024 kern.info kernel: [ 18.250791] Sending QMI_IPA_INIT_MODEM_DRIVER_REQ_V01
Thu May 2 08:41:15 2024 kern.err kernel: [ 18.261962] ipa ipa3_uc_wdi_event_log_info_handler:357 WDI protocol missing 0x21
Thu May 2 08:41:15 2024 kern.err kernel: [ 18.262087] ipa ipa3_uc_ntn_event_log_info_handler:34 NTN stats sz invalid exp=224 is=112 channel count=2
Thu May 2 08:41:15 2024 daemon.notice netifd: Network device ‘lo’ link is up
Thu May 2 08:41:15 2024 kern.info kernel: [ 18.280742] QMI_IPA_INIT_MODEM_DRIVER_REQ_V01 response received
Thu May 2 08:41:15 2024 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Thu May 2 08:41:15 2024 kern.info kernel: [ 18.818925] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Thu May 2 08:41:15 2024 user.err tftp_server[423]: ERR:pid=423 tid=1376 tftp-server : ERR :[tftp_os_la.c, 70] open failed: [2] [No such file or directory]
Thu May 2 08:41:15 2024 user.err tftp_server[423]: ERR:pid=423 tid=1376 tftp-server : ERR :[tftp_server.c, 1708] open failed : [-2] [No error information]
Thu May 2 08:41:15 2024 user.err tftp_server[423]: ERR:pid=423 tid=1376 tftp-server : ERR :[tftp_protocol.c, 1231] sending error-pkt. Code = 1, Msg = Err=2 String=No such file or directory
Thu May 2 08:41:16 2024 user.warn kernel: [ 19.552183] QTI not In MBIM mode.
Thu May 2 08:41:17 2024 user.warn kernel: [ 20.185669] QTI: DPM Init cb
Thu May 2 08:41:17 2024 user.warn kernel: [ 20.222162] QTI:USB peripheral iface enabled
Thu May 2 08:41:17 2024 user.warn kernel: [ 20.257652] QTI:DPM port closed
Thu May 2 08:41:17 2024 daemon.info gsmd[1634]: gsmd-ng init
Thu May 2 08:41:17 2024 daemon.info gsmd[1634]: gsmd-ng canary build git#250b8aa06f
Thu May 2 08:41:17 2024 daemon.info gsmd[1634]: AT traffic support: yes
Thu May 2 08:41:17 2024 daemon.info gsmd[1634]: Baseband feature support: yes
Thu May 2 08:41:17 2024 daemon.info gsmd[1634]: gsmd-ng running
Thu May 2 08:41:18 2024 user.warn kernel: [ 21.272665] QTI:USB tethered modem SMD port opened
Thu May 2 08:41:18 2024 user.warn kernel: [ 21.282859] QTI: Modem In Service
Thu May 2 08:41:18 2024 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Thu May 2 08:41:20 2024 kern.info kernel: [ 23.790161] ipa-wan ipa3_wwan_ioctl:2090 dev(rmnet_data0) register to IPA
Thu May 2 08:41:20 2024 user.notice sysctl: net.ipv6.conf.rmnet_data0.accept_ra = 0
Thu May 2 08:41:20 2024 kern.info kernel: [ 23.932429] ipa-wan ipa3_wwan_ioctl:2090 dev(rmnet_data1) register to IPA
Thu May 2 08:41:20 2024 kern.info kernel: [ 24.079202] ipa-wan ipa3_wwan_ioctl:2090 dev(rmnet_data2) register to IPA
Thu May 2 08:41:21 2024 kern.info kernel: [ 24.206339] ipa-wan ipa3_wwan_ioctl:2090 dev(rmnet_data3) register to IPA
Thu May 2 08:41:21 2024 kern.info kernel: [ 24.336272] ipa-wan ipa3_wwan_ioctl:2090 dev(rmnet_data4) register to IPA
Thu May 2 08:41:21 2024 daemon.info mobifd: [gsm.modem0] Starting modem settings init
Thu May 2 08:41:21 2024 daemon.info mobifd: [gsm.modem0] SIM is ready
Thu May 2 08:41:21 2024 kern.info kernel: [ 24.490779] ipa-wan ipa3_wwan_ioctl:2090 dev(rmnet_data5) register to IPA
Thu May 2 08:41:21 2024 user.err tftp_server[423]: ERR:pid=423 tid=2259 tftp-server : ERR :[tftp_os_la.c, 70] open failed: [2] [No such file or directory]
Thu May 2 08:41:21 2024 user.err tftp_server[423]: ERR:pid=423 tid=2259 tftp-server : ERR :[tftp_server.c, 1708] open failed : [-2] [No error information]
Thu May 2 08:41:21 2024 user.err tftp_server[423]: ERR:pid=423 tid=2259 tftp-server : ERR :[tftp_protocol.c, 1231] sending error-pkt. Code = 1, Msg = Err=2 String=No such file or directory
Thu May 2 08:41:23 2024 authpriv.info dropbear[2444]: Not backgrounding
Thu May 2 08:41:23 2024 daemon.info dnsmasq[999]: exiting on receipt of SIGTERM
Thu May 2 08:41:24 2024 daemon.info mobifd: [gsm.modem0] Modem settings init completed
Thu May 2 08:41:24 2024 daemon.info mobifd: [gsm.modem0] Starting connection setup
Thu May 2 08:41:24 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “15s” of timeout
Thu May 2 08:41:25 2024 cron.err crond[2870]: crond (busybox 1.34.1) started, log level 5
Thu May 2 08:41:25 2024 kern.notice Port link state of port LAN1 changed to UP
Thu May 2 08:41:25 2024 kern.notice Port speed for port LAN1 changed to 1000 baseT
Thu May 2 08:41:26 2024 cron.err crond[3114]: crond (busybox 1.34.1) started, log level 5
Thu May 2 08:41:28 2024 cron.err crond[3564]: crond (busybox 1.34.1) started, log level 5
Thu May 2 08:41:28 2024 daemon.info dnsmasq[3558]: started, version 2.89 cachesize 150
Thu May 2 08:41:28 2024 daemon.info dnsmasq[3558]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Thu May 2 08:41:28 2024 daemon.info dnsmasq[3558]: UBus support enabled: connected to system bus
Thu May 2 08:41:28 2024 daemon.info dnsmasq-dhcp[3558]: DHCP, IP range 192.168.2.100 – 192.168.2.249, lease time 12h
Thu May 2 08:41:28 2024 daemon.info dnsmasq[3558]: using only locally-known addresses for test
Thu May 2 08:41:28 2024 daemon.info dnsmasq[3558]: using only locally-known addresses for onion
Thu May 2 08:41:28 2024 daemon.info dnsmasq[3558]: using only locally-known addresses for localhost
Thu May 2 08:41:28 2024 daemon.info dnsmasq[3558]: using only locally-known addresses for invalid
Thu May 2 08:41:28 2024 daemon.info dnsmasq[3558]: using only locally-known addresses for bind
Thu May 2 08:41:28 2024 daemon.info dnsmasq[3558]: using only locally-known addresses for lan
Thu May 2 08:41:28 2024 daemon.warn dnsmasq[3558]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Thu May 2 08:41:28 2024 daemon.info dnsmasq[3558]: read /etc/hosts - 12 names
Thu May 2 08:41:28 2024 daemon.info dnsmasq[3558]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Thu May 2 08:41:28 2024 daemon.info dnsmasq-dhcp[3558]: read /etc/ethers - 0 addresses
Thu May 2 08:41:29 2024 daemon.info mobifd: [gsm.modem0] Connected to operator “3 3”
Thu May 2 08:41:29 2024 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Thu May 2 08:41:29 2024 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “3 3”
Thu May 2 08:41:29 2024 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “40502”, cell ID: “27535983”, technology: “E-UTRAN”
Thu May 2 08:41:29 2024 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Not registered”, LAC: “”, cell ID: “”, technology: “Unknown”
Thu May 2 08:41:29 2024 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “”, cell ID: “27535983”, technology: “E-UTRAN”
Thu May 2 08:41:29 2024 daemon.info mobifd: [gsm.modem0] -C5GREG- Mode: “Enabled (with location information)”, status: “Not registered”, LAC: “”, cell ID: “”, technology: “Unknown”
Thu May 2 08:41:30 2024 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “109.59.227.11”
Thu May 2 08:41:30 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Thu May 2 08:41:30 2024 daemon.notice netifd: mob1s1a1 (3897): wwan[3897] Searching for a valid wwan usb device…
Thu May 2 08:41:30 2024 daemon.notice netifd: mob1s1a1 (3897): wwan[3897] Using wwan usb device on bus
Thu May 2 08:41:33 2024 daemon.info procd: - init complete -
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): Starting network mob1s1a1 using APN: data.tre.dk
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): Profile successfully modified.
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): Successfully opened the port
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): [/dev/cdc-wdm0] Successfully set data format
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): QoS flow header: no
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): Link layer protocol: ‘raw-ip’
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): Uplink data aggregation protocol: ‘qmapv5’
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): Downlink data aggregation protocol: ‘qmapv5’
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): NDP signature: ‘0’
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): Downlink data aggregation max datagrams: ‘32’
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): Downlink data aggregation max size: ‘63’
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): cid4: 14
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): [/dev/cdc-wdm0] Client ID not released:
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): Service: ‘wds’
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): CID: ‘14’
Thu May 2 08:41:36 2024 daemon.notice netifd: mob1s1a1 (3897): pdh4: 1749066144
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): cid6: 15
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): [/dev/cdc-wdm0] Client ID not released:
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): Service: ‘wds’
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): CID: ‘15’
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): pdh6: 1745980592
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): Notifying WebUI that operator (1280) and configuration MTU (1460) differs
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): Setting up rmnet_data0
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): Setting configured MTU: 1460 on rmnet_data0
Thu May 2 08:41:37 2024 kern.info kernel: [ 40.589665] IPv6: ADDRCONF(NETDEV_UP): rmnet_data0: link is not ready
Thu May 2 08:41:37 2024 kern.err kernel: [ 40.590401] ipa-wan __ipa_wwan_close:1219 [rmnet_ipa0]: ipa3_deregister_intf failed -22
Thu May 2 08:41:37 2024 kern.info kernel: [ 40.609248] IPv6: ADDRCONF(NETDEV_UP): rmnet_ipa0: link is not ready
Thu May 2 08:41:37 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Thu May 2 08:41:37 2024 daemon.notice netifd: Network device ‘rmnet_ipa0’ link is up
Thu May 2 08:41:37 2024 daemon.notice netifd: Network device ‘rmnet_data0’ link is up
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): [/dev/cdc-wdm0] Current settings retrieved:
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): IP Family: IPv4
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): IPv4 address: 109.59.227.11
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): IPv4 subnet mask: 255.255.255.248
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): IPv4 gateway address: 109.59.227.12
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): IPv4 primary DNS: 95.209.200.69
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): IPv4 secondary DNS: 95.209.200.70
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): MTU: 1460
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): Domains: none
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): CID: ‘14’
Thu May 2 08:41:37 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Thu May 2 08:41:37 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
Thu May 2 08:41:37 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is setting up now
Thu May 2 08:41:37 2024 daemon.info mobifd: Method of interface ‘mob1s1a1’ is “passthrough”. Skipping Ping To DNS functionality
Thu May 2 08:41:37 2024 daemon.info mobifd: Connection setup completed for ‘mob1s1a1’
Thu May 2 08:41:37 2024 daemon.info mobifd: Connection setup completed for modem: ‘gsm.modem0’
Thu May 2 08:41:37 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now up
Thu May 2 08:41:37 2024 user.notice firewall: Reloading firewall due to ifup of mob1s1a1 (rmnet_data0)
Thu May 2 08:41:37 2024 daemon.notice netifd: Interface ‘mobile_bridge’ is enabled
Thu May 2 08:41:37 2024 daemon.notice netifd: Interface ‘mobile_bridge’ is setting up now
Thu May 2 08:41:37 2024 daemon.notice netifd: Interface ‘mobile_bridge’ is now up
Thu May 2 08:41:37 2024 daemon.notice netifd: Interface ‘mobile_bridge’ has link connectivity
Thu May 2 08:41:37 2024 daemon.notice netifd: mob1s1a1 (3897): Another app is currently holding the xtables lock. Perhaps you want to use the -w option?
Thu May 2 08:41:39 2024 daemon.info dnsmasq[3558]: exiting on receipt of SIGTERM
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: started, version 2.89 cachesize 150
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: UBus support enabled: connected to system bus
Thu May 2 08:41:39 2024 daemon.info dnsmasq-dhcp[5027]: DHCP, IP range 192.168.2.100 – 192.168.2.249, lease time 12h
Thu May 2 08:41:39 2024 daemon.info dnsmasq-dhcp[5027]: DHCP, static leases only on 109.59.227.11, lease time 1h
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: using nameserver 95.209.200.69#53
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: using nameserver 95.209.200.70#53
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: using only locally-known addresses for test
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: using only locally-known addresses for onion
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: using only locally-known addresses for localhost
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: using only locally-known addresses for invalid
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: using only locally-known addresses for bind
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: using only locally-known addresses for lan
Thu May 2 08:41:39 2024 daemon.warn dnsmasq[5027]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: read /etc/hosts - 12 names
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Thu May 2 08:41:39 2024 daemon.info dnsmasq-dhcp[5027]: read /etc/ethers - 0 addresses
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): Unknown attribute “soft_reset”
Thu May 2 08:41:39 2024 kern.err kernel: [ 42.632386] HIT DWC_ETH_QOS_nway_reset:1289 name:eth0
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): Setting up rmnet_data0 V6 static
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): [/dev/cdc-wdm0] Current settings retrieved:
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): IP Family: IPv6
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): IPv6 address: 2a02:aa7:4648:f400:19aa:7249:ba4e:e173/64
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): IPv6 gateway address: 2a02:aa7:4648:f400:4438:12d6:462f:cf41/64
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): IPv6 primary DNS: 2a02:aa0::57
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): IPv6 secondary DNS: 2a02:aa0::58
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): MTU: 1280
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): Domains: none
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): [/dev/cdc-wdm0] Client ID not released:
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): Service: ‘wds’
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): CID: ‘15’
Thu May 2 08:41:39 2024 daemon.notice netifd: mob1s1a1 (3897): uci: Entry not found
Thu May 2 08:41:39 2024 daemon.notice netifd: Interface ‘mob1s1a1_6’ is enabled
Thu May 2 08:41:39 2024 daemon.notice netifd: Interface ‘mob1s1a1_6’ is setting up now
Thu May 2 08:41:39 2024 daemon.notice netifd: Interface ‘mob1s1a1_6’ is now up
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: reading /tmp/resolv.conf.d/resolv.conf.auto
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: using nameserver 2a02:aa0::57#53
Thu May 2 08:41:39 2024 daemon.info dnsmasq[5027]: using nameserver 2a02:aa0::58#53
Thu May 2 08:41:39 2024 daemon.notice netifd: Interface ‘mob1s1a1_6’ has link connectivity
Thu May 2 08:41:39 2024 kern.info kernel: [ 42.820113] qcom-emac-dwc-eqos 20000.qcom,emac eth0: yt8521, link down.
Thu May 2 08:41:40 2024 daemon.info dnsmasq[5027]: read /etc/hosts - 12 names
KERNEL LOG
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.336 (app@runner-ffjpezdj-project-352-concurrent-1) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16279-5cc0535800), GNU ld (GNU Binutils) 2.34) #0 PREEMPT Mon Apr 15 10:52:22 2024
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Teltonika TRB5XX
[ 0.000000] earlycon: msm_serial_dm0 at MMIO 0x00831000 (options ‘’)
[ 0.000000] bootconsole [msm_serial_dm0] enabled
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] Reserved memory: created DMA memory pool at 0x8f800000, size 4 MiB
[ 0.000000] OF: reserved mem: initialized node audio_region@0, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x8e800000, size 4 MiB
[ 0.000000] OF: reserved mem: initialized node qseecom_ta_region@0, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x8d400000, size 20 MiB
[ 0.000000] OF: reserved mem: initialized node qseecom_region@0, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x8d000000, size 4 MiB
[ 0.000000] OF: reserved mem: initialized node mem_dump_region, compatible id shared-dma-pool
[ 0.000000] Removed memory: created DMA memory pool at 0x90800000, size 248 MiB
[ 0.000000] OF: reserved mem: initialized node mpss_adsp_region@90800000, compatible id removed-dma-pool
[ 0.000000] cma: Reserved 12 MiB at 0x8c400000
[ 0.000000] On node 0 totalpages: 62254
[ 0.000000] free_area_init_node: node 0, pgdat c10b6f24, node_mem_map d0593000
[ 0.000000] Normal zone: 594 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 62254 pages, LIFO batch:15
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 61660
[ 0.000000] Kernel command line: noinitrd ro rootwait console=ttyMSM0,115200,n8 earlycon androidboot.hardware=qcom msm_rtb.filter=0x237 loglevel=10 androidboot.console=ttyMSM0 lpm_levels.sleep_disabled=1 firmware_class.path=/lib/firmware/updates service_locator.enable=1 net.ifnames=0 atlantic_fwd.rx_ring_size=1024 pci=pcie_bus_perf ubi.mtd=rootfs_b ubi.block=0,0 root=/dev/ubiblock0_0 rootfstype=squashfs ubi.mtd=modem ubi.block=1,0 ubi.mtd=storage debug=1 androidboot.serialno=7ca35d33 androidboot.baseband=msm data_interface=[0,0] ql_pcie_mode=0
[ 0.000000] init_pcie_mode: pcie_mode =0
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 187584K/249016K available (10240K kernel code, 960K rwdata, 2880K rodata, 1024K init, 707K bss, 20472K reserved, 40960K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xd1000000 - 0xff800000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0800000 ( 264 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b00000 (11232 kB)
[ 0.000000] .init : 0xc0f00000 - 0xc1000000 (1024 kB)
[ 0.000000] .data : 0xc1000000 - 0xc10f010c ( 961 kB)
[ 0.000000] .bss : 0xc10f55b8 - 0xc11a64c4 ( 708 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_sys_timer depends on broadcast, but no broadcast function available
[ 0.000000] arch_timer: cp15 and mmio timer(s) running at 19.20MHz (virt/virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.010752] Switching to timer-based delay loop, resolution 52ns
[ 0.018740] clocksource: Switched to clocksource arch_sys_counter
[ 0.026107] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.031005] CPU: Testing write buffer coherency: ok
[ 0.041234] pid_max: default: 32768 minimum: 301
[ 0.046428] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.050878] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.058909] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.064621] Hierarchical SRCU implementation.
[ 0.078233] MSM Memory Dump base table set up
[ 0.078300] MSM Memory Dump apps data table set up
[ 0.119577] Duplicate name in mnfinfo, renamed to “name#1”
[ 0.121111] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.124279] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.131644] futex hash table entries: 256 (order: 0, 7168 bytes)
[ 0.143098] pinctrl core: initialized pinctrl subsystem
[ 0.149187] NET: Registered protocol family 16
[ 0.154124] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.158114] cpuidle: using governor menu
[ 0.163976] cpuidle: using governor qcom
[ 0.168209] NET: Registered protocol family 42
[ 0.177520] sd_vdd: regulator get failed, ret=-517
[ 0.179875] unable to find DT imem DLOAD mode node
[ 0.182011] unable to find DT imem EDLOAD mode node
[ 0.186756] unable to find DT imem dload-type node
[ 0.191973] msm_watchdog 17817000.qcom,wdt: wdog absent resource not present
[ 0.195669] msm_watchdog 17817000.qcom,wdt: msm_wdog_dt_to_pdata scandump sizes property not correct
[ 0.203166] msm_watchdog 17817000.qcom,wdt: Couldn’t get memory for dump
[ 0.212087] msm_watchdog 17817000.qcom,wdt: MSM Watchdog Initialized
[ 0.220840] platform 4080000.qcom,mss: assigned reserved memory node mpss_adsp_region@90800000
[ 0.228690] platform soc:mem_dump: assigned reserved memory node mem_dump_region
[ 0.238429] platform 90000000.qseecom: assigned reserved memory node qseecom_region@0
[ 0.248059] platform soc:qcom,msm-audio-ion: assigned reserved memory node audio_region@0
[ 0.255224] No ATAGs?
[ 0.263334] spmi spmi-0: PMIC arbiter version v5 (0x50010000)
[ 0.269886] sps:sps is ready.
[ 0.271983] exit: IPA_USB init success!
[ 0.280316] pmxprairie_s5_level: supplied by pmxprairie_s7_level
[ 0.280721] pmxprairie_s5_level_ao: supplied by pmxprairie_s7_level_ao
[ 0.307393] qmp-aop-clk soc:qcom,aop: Registered clocks with AOP
[ 0.308354] clk-rpmh soc:qcom,rpmh: Registered RPMh clocks
[ 0.313588] KPI: Bootloader start count = 76014
[ 0.317775] KPI: Bootloader end count = 127533
[ 0.322415] KPI: Bootloader display count = 1166295057
[ 0.326717] KPI: Bootloader load kernel count = 15276
[ 0.331860] KPI: Kernel MPM timestamp = 153555
[ 0.336957] KPI: Kernel MPM Clock frequency = 32768
[ 0.341327] socinfo_print: v0.15, id=357, ver=2.0, raw_id=207, raw_ver=2, hw_plat=8, hw_plat_ver=65536
[ 0.341327] accessory_chip=0, hw_plat_subtype=5, pmic_model=65569, pmic_die_revision=131072 foundry_id=1 serial_number=2091081011 num_pmics=2 chip_family=0x5e raw_device_family=0x6 raw_device_number=0xb nproduct_id=0x410 num_clusters=0x1 ncluster_array_offset=0xb0 num_defective_parts=0xd ndefective_parts_array_offset=0xb4 nmodem_supported=0xffffffff
[ 0.364484] msm_bus_fabric_rpmh_init_driver
[ 0.386755] msm_bus: Probe started
[ 0.387569] msm_bus_device 1100000.ad-hoc-bus: Bus type is missing
[ 0.394028] msm_bus_device 1100000.ad-hoc-bus: Bus type is missing
[ 0.402897] msm_bus: DT Parsing complete
[ 0.405370] msm_bus_fab_init_noc_ops: Invalid Bus type
[ 0.406526] msm_bus_fab_init_noc_ops: Invalid Bus type
[ 0.425932] register_client_adhoc:find path.src 53 dest 585
[ 0.426370] arm-smmu 15000000.apps-smmu: non-coherent table walk
[ 0.435451] arm-smmu 15000000.apps-smmu: (IDR0.CTTW overridden by FW configuration)
[ 0.441727] arm-smmu 15000000.apps-smmu: stream matching with 20 register groups
[ 0.450412] register_client_adhoc:find path.src 53 dest 585
[ 0.451023] register_client_adhoc:find path.src 53 dest 585
[ 0.457782] vgaarb: loaded
[ 0.468168] usbcore: registered new interface driver usbfs
[ 0.470703] usbcore: registered new interface driver hub
[ 0.476110] usbcore: registered new device driver usb
[ 0.482012] usb_phy_generic soc:usb_nop_phy: soc:usb_nop_phy supply vcc not found, using dummy regulator
[ 0.487445] qcom,qpnp-power-on c440000.qcom,spmi:qcom,pmxprairie@8:qcom,power-on@800: PMIC@SID8 Power-on reason: Triggered from Hard Reset and ‘cold’ boot
[ 0.496154] qcom,qpnp-power-on c440000.qcom,spmi:qcom,pmxprairie@8:qcom,power-on@800: PMIC@SID8: Power-off reason: Triggered from PS_HOLD (PS_HOLD/MSM Controlled Shutdown)
[ 0.509997] input: qpnp_pon as /devices/platform/c440000.qcom,spmi/spmi-0/spmi0-08/c440000.qcom,spmi:qcom,pmxprairie@8:qcom,power-on@800/input/input0
[ 0.539346] platform soc:qcom,ion:qcom,ion-heap@27: assigned reserved memory node qseecom_region@0
[ 0.539576] platform soc:qcom,ion:qcom,ion-heap@19: assigned reserved memory node qseecom_ta_region@0
[ 0.547414] platform soc:qcom,ion:qcom,ion-heap@28: assigned reserved memory node audio_region@0
[ 0.556911] ION heap system created
[ 0.565643] ION heap qsecom created at 0x8d400000 with size 1400000
[ 0.568613] ION heap qsecom_ta created at 0x8e800000 with size 400000
[ 0.574907] ION heap audio created at 0x8f800000 with size 400000
[ 0.583549] scm_call failed: func id 0x2000c10, ret: -1, syscall returns: 0x0, 0x0, 0x0
[ 0.587544] ipa ipa3_tz_unlock_reg:6958 scm call SCM_SVC_MP failed: -5
[ 0.595421] ipa ipa3_pre_init:7215 Failed to unlock memory region using TZ
[ 0.602236] register_client_adhoc:find path.src 90 dest 774
[ 0.602397] register_client_adhoc:find path.src 134 dest 512
[ 0.609002] register_client_adhoc:find path.src 90 dest 585
[ 0.614422] register_client_adhoc:find path.src 1 dest 676
[ 0.620377] register_client_adhoc:find path.src 143 dest 777
[ 0.630435] iommu: Adding device 1e00000.qcom,ipa:ipa_smmu_ap to group 0
[ 0.637654] iommu: Adding device 1e00000.qcom,ipa:ipa_smmu_wlan to group 1
[ 0.644393] iommu: Adding device 1e00000.qcom,ipa:ipa_smmu_uc to group 2
[ 0.650415] gsi_is_mcs_enabled:1032 MCS enabled:1
[ 0.657117] Using XBL boot load for IPA FW
[ 0.661784] ipa ipa_smmu_ap_cb_probe:8784 AP Geometry start = 0 size= f0000000
[ 0.665752] IPA smmu_info.s1_bypass_arr[AP]=0 smmu_info.fast_map=1
[ 0.684610] IPA smmu_info.s1_bypass_arr[WLAN]=0 smmu_info.fast_map=0
[ 0.685265] IPA smmu_info.s1_bypass_arr[UC]=0 smmu_info.fast_map=0
[ 0.691370] ipa ipa3_uc_state_check:377 uC interface not initialized
[ 0.709577] IPA driver initialization was successful.
[ 0.710490] ipa ipa3_smp2p_probe:8954 fail to get smp2p clk resp bit -517
[ 0.715014] ipa ipa3_smp2p_probe:8954 fail to get smp2p clk resp bit -517
[ 0.723456] pcie:pcie_init.
[ 0.732720] pci-msm: probe of 1c00000.qcom,pcie failed with error -1
[ 0.734633] qcom-cpu-sdxprairie 17810008.qcom,clock-cpu: No speed/PVS binning available. Defaulting to 0!
[ 0.739440] Clock_cpu:(cpu 0) OPP voltage for 345600000: 65
[ 0.747704] Clock_cpu:(cpu 0) OPP voltage for 1555200000: 385
[ 0.753177] qcom-cpu-sdxprairie 17810008.qcom,clock-cpu: CPU clock Driver probed successfully
[ 0.761673] gcc-sdxprairie 100000.qcom,gcc: Registered GCC clocks
[ 0.769658] cpufreq: driver msm up and running
[ 0.773876] ipa ipa3_smp2p_probe:8954 fail to get smp2p clk resp bit -517
[ 0.778930] clocksource: Switched to clocksource arch_sys_counter
[ 0.838415] NET: Registered protocol family 2
[ 0.838886] IP idents hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.842778] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.848325] TCP bind hash table entries: 2048 (order: 3, 40960 bytes)
[ 0.855261] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.861945] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.868175] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.874240] NET: Registered protocol family 1
[ 0.880461] PCI: CLS 0 bytes, default 64
[ 0.885056] ipa ipa3_smp2p_probe:8954 fail to get smp2p clk resp bit -517
[ 0.891937] workingset: timestamp_bits=13 max_order=16 bucket_order=3
[ 0.902335] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.909990] io scheduler noop registered
[ 0.910094] io scheduler deadline registered
[ 0.913486] io scheduler cfq registered (default)
[ 0.917333] io scheduler mq-deadline registered
[ 0.922101] io scheduler kyber registered
[ 0.934971] qcom-sps-dma 804000.qcom,sps-dma: dma_async_device_register: device has no channels!
[ 0.938097] qcom_smp2p: probe of 17811008.qcom,smp2p-modem failed with error -22
[ 0.943953] register_client_adhoc:find path.src 125 dest 512
[ 0.944771] subsys-pil-tz 4080000.qcom,mss: for modem segments only will be dumped.
[ 0.957305] subsys-pil-tz soc:qcom,ipa_fws: for ipa_fws segments only will be dumped.
[ 0.972344] msm_serial 831000.serial: msm_serial: detected port #0
[ 0.972515] msm_serial 831000.serial: uartclk = 1843200
[ 0.977599] 831000.serial: ttyMSM0 at MMIO 0x831000 (irq = 25, base_baud = 115200) is a MSM
[ 0.982895] msm_serial: console setup on port #0
[ 0.991343] console [ttyMSM0] enabled
[ 0.994040] bootconsole [msm_serial_dm0] disabled
[ 1.003412] msm_serial: driver initialized
[ 1.008461] got reovery_uart4a normal system skip
[ 1.012226] register_client_adhoc:find path.src 1 dest 618
[ 1.014899] random: crng init done
[ 1.023093] diag: Pcie registration initiated for id: 0
[ 1.024894] diag: diag_pcie_register: failed registering pcie channels
[ 1.030029] diag: MUX: unable to register pcie operations for proc: 0, err: -22
[ 1.036367] diag: MUX: unable to register PCIe operations, continuing with USB registrations for proc: 0, err: -22
[ 1.051437] diag: Unable to register with PCIE, id: 1
[ 1.053960] diag: MUX: unable to register pcie operations for proc: 1, err: -5
[ 1.059978] diag: MUX: unable to register PCIe operations, continuing with USB registrations for proc: 1, err: -5
[ 1.075575] brd: module loaded
[ 1.082605] loop: module loaded
[ 1.083112] zram: Added device: zram0
[ 1.085420] QSEECOM: qseecom_probe: qseecom.qsee_version = 0x1402000
[ 1.088500] QSEECOM: qseecom_retrieve_ce_data: Device does not support PFE/FDE
[ 1.088511] QSEECOM: qseecom_probe: no-clock-support=0x1
[ 1.095184] QSEECOM: qseecom_probe: qseecom.qsee_reentrancy_support = 2
[ 1.107475] QSEECOM: qseecom_probe: secure app region addr=0x90000000 size=0x500000
[ 1.110243] QSEECOM: qseecom_probe: qseecom.whitelist_support = 1
[ 1.123728] register_client_adhoc:find path.src 91 dest 512
[ 1.125360] sps: BAM device 0x01b04000 is not registered yet.
[ 1.133522] sps:BAM 0x01b04000 is registered.
[ 1.133538] msm_nand_bam_init: msm_nand_bam_init: BAM device registered: bam_handle 0xca432200
[ 1.143652] sps:BAM 0x01b04000 (va:0xd1820000) enabled: ver:0x19, number of pipes:9
[ 1.152333] msm_nand_version_check: nand_major:2, nand_minor:0, qpic_major:2, qpic_minor:0
[ 1.159537] msm_nand_parse_smem_ptable: Parsing partition table info from SMEM
[ 1.167764] msm_nand_parse_smem_ptable: SMEM partition table found: ver: 4 len: 26
[ 1.174890] msm_nand_version_check: nand_major:2, nand_minor:0, qpic_major:2, qpic_minor:0
[ 1.182467] msm_nand_flash_onfi_probe: msm_nand_flash_onfi_probe: no apps partition found in smem
[ 1.190717] msm_nand_scan: NAND Id: 0x2680ac2c Buswidth: 8Bits Density: 512 MByte
[ 1.199579] msm_nand_scan: pagesize: 4096 Erasesize: 262144 oobsize: 256 (in Bytes)
[ 1.207028] msm_nand_scan: BCH ECC: 8 Bit
[ 1.214489] msm_nand_scan: CFG0: 0x290409c0, CFG1: 0x08045d5c
[ 1.214489] RAWCFG0: 0x2b8401c0, RAWCFG1: 0x0005055d
[ 1.214489] ECCBUFCFG: 0x00000203, ECCBCHCFG: 0x42040d10
[ 1.214489] RAWECCCFG: 0x42000d11, BAD BLOCK BYTE: 0x00000175
[ 1.222614] Creating 26 MTD partitions on “1b00000.nand”:
[ 1.244890] 0x000000000000-0x000000280000 : “sbl”
[ 1.251350] 0x000000280000-0x000000380000 : “mibib”
[ 1.255709] 0x000000380000-0x000001980000 : “efs2”
[ 1.260442] 0x000001980000-0x000001c00000 : “rawdata”
[ 1.265263] 0x000001c00000-0x000001f80000 : “sys_rev”
[ 1.270489] 0x000001f80000-0x000002200000 : “cust_info”
[ 1.275404] 0x000002200000-0x000002400000 : “tz”
[ 1.280507] 0x000002400000-0x000002540000 : “tz_devcfg”
[ 1.285277] 0x000002540000-0x000002680000 : “ddr”
[ 1.290306] 0x000002680000-0x0000027c0000 : “apdp”
[ 1.295098] 0x0000027c0000-0x000002900000 : “xbl_config”
[ 1.299895] 0x000002900000-0x000002a40000 : “aop”
[ 1.305254] 0x000002a40000-0x000002b80000 : “qhee”
[ 1.309960] 0x000002b80000-0x000002cc0000 : “abl”
[ 1.314519] 0x000002cc0000-0x000002f40000 : “uefi”
[ 1.319404] 0x000002f40000-0x000003080000 : “mnf_info”
[ 1.324015] 0x000003080000-0x0000031c0000 : “boot_config”
[ 1.329240] 0x0000031c0000-0x000003fc0000 : “boot_a”
[ 1.334812] 0x000003fc0000-0x000004dc0000 : “boot_b”
[ 1.339780] 0x000004dc0000-0x000004f00000 : “misc”
[ 1.344565] 0x000004f00000-0x00000c000000 : “modem”
[ 1.349317] 0x00000c000000-0x00000c140000 : “ipa_fw”
[ 1.353965] 0x00000c140000-0x00000c280000 : “usb_qti”
[ 1.359325] 0x00000c280000-0x000014380000 : “rootfs_a”
[ 1.364160] 0x000014380000-0x00001c480000 : “rootfs_b”
[ 1.369237] 0x00001c480000-0x000020000000 : “storage”
[ 1.374281] msm_nand_probe: NANDc phys addr 0x1b00000, BAM phys addr 0x1b04000, BAM IRQ 34
[ 1.378898] msm_nand_probe: Allocated DMA buffer at virt_addr 0xcc440000, phys_addr 0x8c440000
[ 1.386984] msm_nand_probe: Host capabilities:0x00000000
[ 1.404325] MNFINFO PROPERTIES:
[ 1.404391] mac : 20972713387F
[ 1.406314] name : TRB50000XXXX
[ 1.410248] serial : 6001003096
[ 1.413688] hwver : 0004
[ 1.416897] branch :
[ 1.419949] batch : 0012
[ 1.422451] sim_count: 1
[ 1.426062] MACsec IEEE 802.1AE
[ 1.428913] tun: Universal TUN/TAP device driver, 1.6
[ 1.430930] PPP generic driver version 2.4.2
[ 1.436197] usbcore: registered new interface driver asix
[ 1.440545] usbcore: registered new interface driver ax88179_178a
[ 1.445687] usbcore: registered new interface driver cdc_ether
[ 1.451806] usbcore: registered new interface driver smsc75xx
[ 1.457493] usbcore: registered new interface driver smsc95xx
[ 1.463347] usbcore: registered new interface driver net1080
[ 1.469053] usbcore: registered new interface driver cdc_subset
[ 1.474760] usbcore: registered new interface driver zaurus
[ 1.481009] usbcore: registered new interface driver cdc_ncm
[ 1.489486] sd_vdd: supplied by vddpx_2
[ 1.493888] iommu: Adding device a600000.ssusb to group 3
[ 1.498098] dwc3 a600000.dwc3: changing max_speed on rev 00000000
[ 1.505349] register_client_adhoc:find path.src 61 dest 512
[ 1.505866] register_client_adhoc:find path.src 61 dest 676
[ 1.507232] register_client_adhoc:find path.src 1 dest 583
[ 1.514113] Invalid index Defaulting curr to 0
[ 1.524473] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.528005] ehci-pci: EHCI PCI platform driver
[ 1.536038] usbcore: registered new interface driver cdc_acm
[ 1.539705] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.544856] usbcore: registered new interface driver usb_ehset_test
[ 1.552583] usbcore: registered new interface driver lvs
[ 1.560320] udc-core: couldn’t find an available UDC - added [g_ether] to list of pending drivers
[ 1.565534] i2c /dev entries driver
[ 1.574083] register_client_adhoc:find path.src 86 dest 512
[ 1.587907] usbcore: registered new interface driver usbhid
[ 1.592964] tz_log 1468f720.tz-log: Hyp log service is not supported
[ 1.599357] usbhid: USB HID core driver
[ 1.605900] ipa_ut ipa_ut_module_init:1045 Loading IPA test module…
[ 1.609857] register_client_adhoc:find path.src 1 dest 627
[ 1.611167] register_client_adhoc:find path.src 1 dest 512
[ 1.616260] register_client_adhoc:find path.src 1 dest 512
[ 1.624933] Netfilter messages via NETLINK v0.30.
[ 1.631164] nf_conntrack version 0.5.0 (4096 buckets, 16384 max)
[ 1.635821] ctnetlink v0.93: registering with nfnetlink.
[ 1.642047] ip_set: protocol 6
[ 1.647171] ipip: IPv4 and MPLS over IPv4 tunneling driver
[ 1.650479] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.655744] arp_tables: arp_tables: (C) 2002 David S. Miller
[ 1.661351] NET: Registered protocol family 10
[ 1.667390] Segment Routing with IPv6
[ 1.670904] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.674894] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.680377] NET: Registered protocol family 17
[ 1.685660] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.690217] Ebtables v2.0 registered
[ 1.703443] 8021q: 802.1Q VLAN Support v1.8
[ 1.709288] dwc3 a600000.dwc3: changing max_speed on rev 00000000
[ 1.711179] using random self ethernet address
[ 1.716959] using random host ethernet address
[ 1.721862] ecm0: HOST MAC b6:52:db:16:62:34
[ 1.725726] ecm0: MAC c2:f5:a6:44:fb:8e
[ 1.730247] using random self ethernet address
[ 1.733711] using random host ethernet address
[ 1.738296] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 1.742723] g_ether gadget: g_ether ready
[ 1.751921] register_client_adhoc:find path.src 61 dest 512
[ 1.752312] register_client_adhoc:find path.src 61 dest 676
[ 1.753507] register_client_adhoc:find path.src 1 dest 583
[ 1.758848] usb_bam_init: setting SPS_BAM_SMMU_EN flag with (a704000.qcom,usbbam)
[ 1.770603] sps:BAM 0x0a704000 is registered.
[ 1.788882] ubi0: attaching mtd24
[ 1.829021] msm-dwc3 a600000.ssusb: DWC3 exited from low power mode
[ 1.829860] msm-dwc3 a600000.ssusb: DWC3 in low power mode
[ 1.838789] msm-dwc3 a600000.ssusb: Could not get usb psy
[ 1.919071] ubi0: scanning is finished
[ 1.924539] ubi0: attached mtd24 (name “rootfs_b”, size 129 MiB)
[ 1.924580] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
[ 1.929669] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
[ 1.936306] ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
[ 1.943176] ubi0: good PEBs: 516, bad PEBs: 0, corrupted PEBs: 0
[ 1.949944] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
[ 1.956187] ubi0: max/mean erase counter: 4/2, WL threshold: 4096, image sequence number: 670962332
[ 1.963234] ubi0: available PEBs: 0, total reserved PEBs: 516, PEBs reserved for bad PEB handling: 40
[ 1.972184] ubi0: background thread “ubi_bgt0d” started, PID 183
[ 1.981565] ubi1: attaching mtd20
[ 2.091362] ubi1: scanning is finished
[ 2.096731] ubi1: attached mtd20 (name “modem”, size 113 MiB)
[ 2.096771] ubi1: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
[ 2.101511] ubi1: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
[ 2.108239] ubi1: VID header offset: 4096 (aligned 4096), data offset: 8192
[ 2.115109] ubi1: good PEBs: 452, bad PEBs: 0, corrupted PEBs: 0
[ 2.121876] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2.128118] ubi1: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 780157798
[ 2.135168] ubi1: available PEBs: 0, total reserved PEBs: 452, PEBs reserved for bad PEB handling: 40
[ 2.144115] ubi1: background thread “ubi_bgt1d” started, PID 184
[ 2.153495] ubi2: attaching mtd25
[ 2.214833] ubi2: scanning is finished
[ 2.219993] ubi2: attached mtd25 (name “storage”, size 59 MiB)
[ 2.220032] ubi2: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
[ 2.224728] ubi2: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
[ 43.860456] qcom-emac-dwc-eqos 20000.qcom,emac eth0: Link is Down
[ 43.868160] br-lan: port 1(eth0) entered disabled state
[ 45.940378] qcom-emac-dwc-eqos 20000.qcom,emac eth0: yt8521, link up, UTP, reg 0x11=0xbc00.
[ 45.940435] qcom-emac-dwc-eqos 20000.qcom,emac eth0: yt8521, link up, media UTP, reg 0x11=0xbc00.
[ 45.963247] qcom-emac-dwc-eqos 20000.qcom,emac eth0: Link is Up - 1Gbps/Full - flow control off
[ 45.963728] br-lan: port 1(eth0) entered blocking state
[ 45.970835] br-lan: port 1(eth0) entered forwarding state
[ 50.236090] NOHZ: local_softirq_pending 08
[ 50.236126] NOHZ: local_softirq_pending 08
[ 50.300915] NOHZ: local_softirq_pending 08
[ 50.300951] NOHZ: local_softirq_pending 08
[ 50.466017] NOHZ: local_softirq_pending 08
[ 50.466053] NOHZ: local_softirq_pending 08
[ 50.477159] NOHZ: local_softirq_pending 08
[ 50.477191] NOHZ: local_softirq_pending 08
[ 50.535914] NOHZ: local_softirq_pending 08
[ 50.535947] NOHZ: local_softirq_pending 08
