Trying to list network operators in WebUI and also in CLI fails.
Would anyone have an idea why?
root@RUT956:~# gsmctl -A AT+COPS=?
[handle_requests:429] error: Failed to handle AT exec. ERR: Request timed out
The command, I believe, is gsmctl -A AT+COPS? without the = sign.
That works but only lists the currently connected operator. COPS=? is to list available network operators. AT+COPS – AT Command For Operator Selection | Onomondo I took it originally from a teltonika document. Regardless it doesn’t work from the WebUI and I suspect this is why.
Interestingly enough, if I try to scan operators through the WebUI, it works just fine. Scanning through the CLI with the command you’ve provided returns the same error message as well ![]()
