jet
1
Using RUTX11.
All was working fine with 07.18.3 preview version.
BUT after loading the latest official(!!) firmware update (00.07.18.3) broke all my WiFi connections!! (equipments are not connecting)
Noticed also that the new preview version branch (00.7.19) has the same issue - equipments are not connecting!
Could you please clarify some information:
- What devices are you trying to connect to the WiFi with?
- Is the WiFi network discoverable, but you can’t connect to it, or devices do not see it at all?
Could you please try changing the encryption to WPA3-SAE and see if that works.
jet
4
Already reverted back to working 07.18.3 preview version..
Could you please clarify what you mean by the preview version of 7.18.3? Also, where did you download it?
jet
6
From your server.. The beta that was available thru the modem setup “Update firmware” page.. /system/flashops/general/ “Latest firmware“
My apologies for the delayed response.
To investigate these issues further, we will need a troubleshoot file downloaded after the problems occur on the newer firmware version.
Would you like to proceed with the troubleshooting steps? If so, you would need to recreate the issues as previously mentioned.
system
Closed
9
