LAN setup using building dhcp
Setting up RUTX10 to use building dhcp
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 17736.
To obtain DHCP from the upstream router, a new LAN interface with a static IP address within the upstream router’s DHCP pool was created. Then a new VLAN, the required ports were assigned to it, and the VLAN was linked to the new LAN interface under physical settings.
