Hello.
I have 4 different LAN configured in my RUTX50 router. One in each LAN interface. My WAN interface is mob1s1a1.
I want 192.168.1.0/24 to have access to the internet and to the router administration and the other three LAN (192.168.2.0/24, 10.10.2.0/24 and 10.100.2.0/24) to access internet and not access router administration(web, telnet, CLI).
The simplest solution would likely be to set up a firewall rule to block/reject traffic from these LAN networks (192.168.2.0/24, 10.10.2.0/24, and 10.100.2.0/24) coming to your router. If you encounter any issues configuring this, don’t hesitate to contact us. However, this process should be fairly straightforward in general.
Thank you for your quick response.
When I create the FW rule it seems DNS requests are blocked.
Cant reach internet using a web browser.
Here is my rule:
When selecting zones keep in mind that you want to prohibit traffic from LAN to LAN in this case both zones (marked in the image below) should be set to LAN. Don’t forget to assign prohibited ports too
