Issues with Wireguard Peer
Dear Team,
I’m facing issues with RUT241 establishing a peer connection with my vpn provider thru wireguard.
Something is wrong and i’m not able to pass anything thru the tunnel, i believe the issue is DNS.
My config
Can someone tell me where im mistaking ?
Thanks in advance,
A few remarks:
  • Wireguard peer ch_prot: set Allowed IPs to 0.0.0.0/1 + 128.0.0.0/1
  • Zones: set wireguard=>lan to Accept/Accept/Accept
  • DNS->General settings: disable Rebind protection and set Listen interfaces to lan
From a ssh or CLI console, execute the command “wg”. What is the output (hide sensitive fields) ?
Thanks for your input.
I’ve tried however same thing, here it goes the output.:
root@Teltonika-RUT241:~# wg
interface: ch_prot
public key: key
private key: (hidden)
listening port: 51820
peer: peer
preshared key: (hidden)
endpoint: 14x.x.x.x:51820
allowed ips: 0.0.0.0/1, 128.0.0.0/1
transfer: 0 B received, 12.29 KiB sent
persistent keepalive: every 20 seconds
root@Teltonika-RUT241:~# nslookup 8.8.8.8
;; connection timed out; no servers could be reached
any other possibility ?
Thanks in advance,
Could you execute a tcpdump:
tcpdump -i any -n -v 'port 51820'
You shoud see outgoing frames, but do you see something coming back in ?
For testing, restrict Allowed Ips to one known value only and try to ping it (87.248.114.11/32 will do).
Hi Flebourse
I’ve tried however the tcpdump doesnt give any clue. The packet goes out but doesnt return. I’ve configured with another vpn server and same thing.
I was reading another thread and another user passed thru the same. At this point i guess the issue is with teltonika firmware, unless someone made it work.
The headache to use wireguard doesnt worth, i will keep with openvpn.
ps.: ive tried the same config with pfsense and works without issues.
Thanks a lot for your help brother and im sorry for bother you.
Have you checked the keys ?
Hello
Yes… im using the same configs on pfsense and its working.
Something is wrong at teltonika router, i suppose.
By the numbers of threads around internet about the same. its a pity. i really like teltonika
I am facing the same issue, been fiddling with this for a month now nothing has worked, i really think this is on the teltonika side, and i really hope they will fix this issue soon, i have rutx50, and i cannot connect to any ports everything is closed if i try portscanner i am using mobile internet not using wan.
