Issues with modem - router
Hi I have a RUT200 and i have been experiencing issues with the operator signal, I have others routers with same operator and I don’t have any problems, I have noticed that usually the blocking or issue comes after some ip block firewall rule, I’m not sure since I’m not into firewalls completely, also I’m not sure if that’s the case. Router has full signal at its best probably in any band near there, yet still manages to get lost and even doesn’t load, I attribute that to traffic issues, not sure, please help with this situation.
Thanks in advance.
Please tell me if there’s need of more info.
It’s highly unlikely that firewall rules would affect the signal directly, as they typically regulate traffic passing through your connection.
Could you provide more details about the issue you’re experiencing? When does it occur? Does it follow a specific pattern? Are you losing the data connection or the signal itself? This information will greatly assist us in resolving the issue.
Marijus
