Issue with Bi-Directional VPN Connection Using RMS VPN Hubs
Hello everyone,
I am currently working with Teltonika’s RMS VPN Hub feature to establish a connection between two RUT950 devices, which I will refer to as Device A and Device B. Here is the setup:
- Device A has a computer with the IP address 192.168.1.10 connected to it.
- Device B has a computer with the IP address 192.168.1.20 connected to it.
I have successfully used the RMS VPN application on the computer connected to Device A (192.168.1.10) to connect to the computer connected to Device B (192.168.1.20) using the Hercules application. However, I am facing an issue where I need the computer with IP 192.168.1.20 to connect back to 192.168.1.10 without using the RMS VPN app.
Current Configuration:
- RMS VPN Hub: Configured to allow both Device A and Device B to connect to each other.
- Device A (192.168.1.10): Can successfully connect to Device B (192.168.1.20) using Hercules with the help of RMS VPN app.
- Device B (192.168.1.20): Needs to connect back to Device A (192.168.1.10) without using RMS VPN app.
Despite having a working one-way connection from Device A to Device B, I am unable to establish a connection in the reverse direction from Device B to Device A without utilizing the RMS VPN app. My goal is to have bi-directional connectivity without installing additional software on the computer at 192.168.1.20.
I would greatly appreciate any guidance or suggestions on how to configure this setup to allow Device B to connect to Device A without the need for the RMS VPN application. If anyone has experience with a similar setup or can point me in the right direction, it would be extremely helpful.
Thank you for your time and assistance.
