Hi, i would like to clarify is there any best practices or hardening guideline for NTP001 NTP Server
You can find our general security guidelines here: Security Guidelines - Teltonika Networks Wiki
Since the NTP001 is only an NTP server, many of the recommendations in the guide (such as firmware management and Wi-Fi security) are not applicable. However, you can still follow the applicable best practices, such as restricting administrative access, changing the SSH authentication method, and implementing other basic security measures.
Here is the documentation on modifying access control: NTP001 Administration - Teltonika Networks Wiki
Hi Justinas,
Thank you for the response, can i trouble you to help to list down what is applicable for the NTP001?
Best regards
I have marked what is applicable directly on the NTP001
Use a VPN for Remote Access - The NTP001 does not natively run standard VPN client protocols (such as IPsec, OpenVPN, or WireGuard). However, if remote administrative access is required, you can route that traffic through an external gateway VPN.
Sorry to trouble you again, is there any step by step guide on how to implement those applicable items.
Hello @Youyi_support,
For configuring complex password requirements, you can adjust the password in the device’s WebUI under System → Administration → User Settings.
For more information, please refer to the following Wiki article:
For External system logging, you can review the device’s event logs under System → Maintenance → Troubleshoot → Logging Settings.
More information can be found here:
For Key-Based SSH Authentication, navigate to System → Administration → Access Control → SSH. Switch authentication from password-based to key-based authentication, and once key-based authentication has been confirmed to work correctly, disable password-based SSH login.
You can also change the default SSH port to a non-standard port from this section if required.
More information:
For managing user permissions, navigate to System → Administration → User Settings → System Users. Here, you can create users and groups and assign specific permissions to each group according to your requirements.
More information:
To disable unused services, navigate to Status → Services. From there, you can review the available services and disable any that are not required.
More information:
If required, you can also encrypt device configuration backups under System → Maintenance → Backup.
More information:
For additional information on the NTP001 and guidance, please refer to the following Wiki articles:
If you have any issues configuring a specific service or setting, please do not hesitate to contact us.
P.
Thanks for the steps provided.
Can i also check is the NTP device running on a proprietary system and may not be able to do credential scanning through common VA tools?
Currently we in the progress of doing some VA scans
The NTP001 runs RutOS it is a Linux based operating system built on OpenWrt. It supports standard SSH access over port 22, so your vulnerability scanning tool should be able to establish an authenticated SSH session.
Hi, why do you want to remove chacha20?
not sure what classifies as proprietary, but it is their own firmware that was developed based on OpenWRT
Hi Alphornits,
Because our environment doesn’t allow chacha20.
ok possible to get any insight on why the scan method failed?
Hi as per the conversation earlier, can i have the response for this query.
RutOS is developed by Teltonika Networks, based on the open-source OpenWrt/Linux platform. The supplied licensing documentation identifies open-source components alongside proprietary firmware components that carry specific redistribution permissions. It is therefore more accurate to describe RutOS as firmware containing components governed by multiple licences.
The availability of GPL-licensed source code permits commercial distribution of the covered components, subject to the applicable licence conditions. However, it does not, by itself, establish permission to redistribute the complete RutOS firmware on independently manufactured devices. Such use requires verification of the licences applicable to all included components.
You can find more information here:
T.
Hi Tautvydas,
Thank you for the response on the proprietary firmware.
What about the removal of CHACHA20 cipher? appreciate for any responses
Any response regarding the removal of CHACHA20 cipher?
Regarding the chacha20-poly1305 cipher, the NTP001 runs RutOS, Teltonika’s customized Linux distribution based on OpenWrt. SSH access and encryption are handled by the relevant system services, such as Dropbear or OpenSSH, depending on the firmware configuration.
There is no standard option in the NTP001 WebUI to selectively disable individual cryptographic ciphers, such as chacha20-poly1305, for SSH or HTTPS services.
Please note that manually modifying the system’s cryptographic configuration via the CLI is generally not officially supported. Additionally, firmware upgrades may overwrite manual changes to system configuration files.
Scanners usually flag chacha20-poly1305 because of the Terrapin issue, CVE-2023-48795. That issue affects the SSH server software, including Dropbear through 2022.83. Dropbear added a “strict key exchange” mitigation for it. Some projects chose instead to compile the cipher out of Dropbear. That is a build-time change and can’t be done afterwards
Scanners usually flag this cipher because of the Terrapin issue, CVE-2023-48795. It affects SSH server software, including Dropbear through 2022.83, and the fix is a “strict key exchange” mitigation in the SSH server. We are checking with our R&D department whether the cipher in the NTP001 firmware can be disabled. Some projects chose instead to compile the cipher out of Dropbear. That is a build-time change and can’t be done afterwards. We will update you once we have an answer.
In the meantime, you have these options:
- Disable SSH access if you don’t need it. In System → Administration → Access Control, turn off SSH access.
- Restrict SSH access if you do need it. Limit who can reach it, and use key-based authentication.
- Build custom firmware. The NTP001 SDK is available on the NTP001 Firmware Downloads page, if the SSH server’s configuration options allow this change. Custom firmware is used at your own risk and may affect device functionality or compatibility with RMS.
For more information, please refer to the following resources:
Please note that custom firmware modifications are performed at your own risk and may affect device functionality or compatibility with RMS.
Hope this helps.
P.
