Hello, got some routers that are using a lot of data and want to limit it potentially running out so was wondering if there was a way to limit data usage?
Cheers.
Cheers.
Yes, it is possible to set up a data limit for your router directly through the WebUI. You can enable this feature by navigating to Network → Mobile → Limits. By default, the data limit will reset every day at 00:00.
For more detailed information on configuring data limits, please refer to the following page: Data Limit Information.
Oh cool, interesting that it doesn’t come up when using the search feature.
Appreciate the assistance.
Thank you for the feedback! I can confirm that on the latest firmware version, RUT2M_R_00.07.10.2, you should be able to locate this feature by typing “data limit” directly in the Search bar.
Glad to assist, and please feel free to reach out if you have more questions.
Ah, must be the firmware version then. On 7.07.3 it doesn’t show up. Thanks again for the help.
