Is it possible to connect a RUTX to a machine via USB?
Hello: I have a streaming machine with a direct connection to Ethernet. It also has a USB connection to connect a starphone in tethering mode in case the internet fails. Is it possible to connect RUTX 11 or 12 so that the machine detects it as a starphone and can connect to the internet in tethering mode?
Thank you
USB tethering is not currently supported on RUTX devices, so they cannot use USB as a LAN port. While the R&D team has received suggestions to add this feature, there’s no confirmation on if or when it will be implemented.
