IPSec Client without "Remote identifier"?
Hello, I try to connect to my VPN Server via IPSec.
If I want to use a domain, I always have to set up a “Remote identifier” (rightid) in the Client (the IP Address in my case).
With other vendors, it works flawlessly. Only in my RUTX12 I have to set the “rightid”. What can I do to make my RUTX12 ignore the “rightid” and connect with IPSec anyway?
Could you try using %any in the RightID field to check if the device is able to connect to other IPsec hosts?
Alternatively, the field can be left empty. The same can be done for the LeftID as well.
