Iperf3 Segmentation Fault
regarding to Rut300 iperf3 Segmentation fault still
seams not be fixed on my RUT951 with latest Firmware RUT9M_R_00.07.15
Are there any updates?
question for you - did you try run it as a client or a server ?
your example was just trying to run it without any args, which is a bit weird.
it needs args, for example to run it as a server/daemon:
/usr/local/usr/bin/iperf3 -s -D
yes, sure
iperf3 -s and with full path as you wrote end in segmentation fault
damn, anything else on the system segfaulting ? did you remove/re-add iperf ?
it may be worth sha256sum ing the iperf3 file - also check the size with ls -la
I recognise your build might be different but here are my results:
root@RUTM52:~# sha256sum /usr/local/usr/bin/iperf3
a3a35e9660dbfb6234b805aa4d0eb7a739112a9f1018c7e317bee390618653ab /usr/local/usr/bin/iperf3
root@RUTM52:~# ls -lah /usr/local/usr/bin/iperf3
-rwxr-xr-x 1 root root 8.0K Jun 4 12:34 /usr/local/usr/bin/iperf3
root@RUTM52:~# uname -a
Linux RUTM52 6.6.87 #0 SMP Wed Jun 4 10:34:44 2025 mips GNU/Linux
Yes I already did. Same result
Here aree may results
`root@RUT951:~# sha256sum /usr/local/usr/bin/iperf3
9ef52c50fa538c5af1acebaf70c3fc3f44fb6985027101b8366acab3eef5fc16 /usr/local/usr/bin/iperf3
root@RUT951:~# ls -lah /usr/local/usr/bin/iperf3
-rwxr-xr-x 1 root root 6.4K Jun 4 12:34 /usr/local/usr/bin/iperf3
root@RUT951:~# uname -a
Linux RUT951 5.15.180 #0 Wed Jun 4 10:34:44 2025 mips GNU/Linux
root@RUT951:~# iperf3 -h
Segmentation fault
root@RUT951:~# iperf3 -S
Segmentation fault`
Hello @mschl,
Unfortunately, I still haven’t received any updates from our developers regarding this issue. As soon as I receive any news, I will inform you right away.
We appreciate your understanding and patience.
Be informed that there is no 7.15 for rut300 either. I’m tiered to report this each time so this is my last call. thx.
are there any updates?
The issue will most likely be reviewed by our developers next week. I will inform you as soon as I receive any feedback from them.
Thank you for your patience.
Hello @Marija,
thank you for the upadate. I’m looking forward to hearing more as soon as there is any news from the developers.
Best regards
Hello @mschl,
Hope you’re doing well!
I wanted to inform you that the fix for this issue will be included in the RutOS firmware version 7.17.
Hi @Marija,
thanks for that update.
You ae welcome!
Once the 7.17 firmware becomes available, I’ll let you know.
Hello @Marija ,
i can confirm, that the bug is now fixed with firmware 7.17
Thanks for your support.
Best regards
Thank you for confirming!
Feel free to reach out on the forum if there’s anything else we can assist you with.
No solution for rut300: no 7.17 available… Sry to use this thread but it’s related and the original is closed. Please provide 7.17 for rut300 as promised. thx
