Hello, I want to make such a plan. I have tws202 switch and rut241 and 3 other devices that I want to configure. Can you please help me how I can change the IP address and give a specific IP address for a specific device through the router. Thanks
Hi @Mohamed!
Not clear what you want.
- you are using 172.168.1.x range, that is NOT a private IP address range and will most likely cause problems.
- you have five devices but only three IP addresses - why?
- you have to configure each device with the IP address that you want
- does the switch have an IP address of its own?
- anyway why would you need different IP addresses on the different switch ports?
Provide more and clearer information and someone might be able to help.
Timelapse Admin
