IOS App connect rutx50
After a rebuild of my mobile phone I’m unable to connect with the iOS RutOS app to my Rutx50.
Via a browser it works fine. When I press discover device it is an unable to find it. When I try to search manually it doesn’t find a device via WiFi. Neither the WiFi search or the IP-adres I use to acces the rutx50 via the browser.
Help
On your iPhone, in Settings - Teltonika RUTOS - “Local Network” is enabled?
Yes it is enabled
Can you make sure your RUTX50 is running on the latest firmware version 07.07.2
RUTX50 Firmware Downloads - Teltonika Networks Wiki
And of course RutOS App for iOS needs to be the most current one: 1.9.3
Can you confirm your app version is 1.9.3?
This version is just 5 days old - hence asking…
The solution was pretty simple. Somehow the ip number my iPhone used was blocked
Okay, glad to hear you’ve solved your issue :slight_smile:
