Install OpenWrt on RUT955 via tftp
Is it possible to install OpenWrt on a RUT 955 via tftp?
I found this guide but it doesn’t mention which files should be used.
Many thanks in advance for any help.
Greetings, @balanga,
Thank you for your question.
You mentioned that you found a guide - could you please share it with me? Seeing the exact steps will help me advise you properly.
As a general note, installing a different operating system on the device is not something we can officially support. Some services, such as mobile connectivity, may not function correctly, and there is a real risk of rendering the device unusable if the procedure goes wrong.
Once I review the guide, I can provide more accurate feedback.
Looking forward to your reply.
