Inquiry Regarding Digital Input Electrical Characteristics of RUT906
Dear Teltonika Support Team,
I would like to request detailed information regarding the Digital Input (DI) interface of the RUT906 device.
Specifically, could you please confirm the following parameters:
  1. The input impedance (resistance) of the DI circuit
  2. Whether any internal pull-up or pull-down resistors are applied
  3. The expected input current when a 12 V signal is applied
  4. Any other available details related to the DI input electrical characteristics
This information will help us ensure proper interfacing between the RUT906 and our external equipment.
Thank you in advance for your assistance.
Hi, @Lukas.Kim
Have you check at this url?
Hi there, Lukas,
Could you kindly check both the link that Marcelo has provided: QSG RUT906 - Teltonika Networks Wiki & the following link as well: RUT906 Input/Output - Teltonika Networks Wiki
Hi Matas,
I already reviewed the Wiki, but I couldn’t find the information.
If this information is not available, Could you please let me know the vendor and model name of the digital input module used in RUT906?
Hi, Lukas,
I’ll try contacting our R&D for these details. It may take a while to come back with a response, so I highly appreciate your patience.
