I/O POST/GET Going Away in 7.14?
Is it true that the I/O Post/Get is being removed and being replace with API with 7.14? If so, does anybody have an example of how to toggle the Output pin using Curl and the API? The API documentation for I/O pin configuration is sparse IMO.
Yes, check Implementation of Read-Only System Files and Mobile and I/O POST/GET Service Removal with RutOS 7.14
For API documentation use https://developers.teltonika-networks.com/reference/rutx50/7.13.1/v1.5/input-output#post-io-id-actions-change_state
Hello @SteveT44,
Could you please confirm whether your issue has been resolved or if you still require assistance?
Hello @Marija, I am using the “time” parameter to turn off the output pin after 500 ms, how can I do it with API ?
No, I have not yet had the chance to work with the API yet.
Hello @SteveT44,
Please let me know once you’ve had a chance to try it and whether it works for you.
Hello @f.coulon,
Could you please create a separate topic for this issue so we can address it more effectively?
