I can't add a Wi-Fi network to a RUTX 12
Hello:
I can’t add a Wi-Fi network to a RUTX, the IP doesn’t appear. I follow the instruction video but it is not possible to connect.
Thank you.
Thanks for contacting Teltonika Networks’ technical support team.
If you want to create a basic Wi-Fi access point for other devices, follow these steps:
  • Connect to the WebUI.
  • Go to Network → Wireless → SSIDs
  • Press ADD near your desired Wi-Fi radio
  • Enable the instance
  • Make sure the Mode parameter (in the general setup section) is set to Access Point
  • Set the ESSID (the Wi-Fi name) and password
By default, a new Wi-Fi access point uses the LAN network’s interface. If you want to change that or create a new LAN interface for the new access point, then set the Network parameter accordingly. For a new LAN interface select the Auto (wifi*) setting.
Additional settings can be found in their respective tabs on the left/top side of the configuration window.
  • Press Save & Apply
After completing these steps, the router should provide a new basic Wi-Fi access point for other devices.
If you want to connect the router to an existing Wi-Fi, follow these steps:
  • Press SCAN near your desired Wi-Fi radio
  • After the scan finishes press JOIN NETWORK near your desired Wi-Fi network
  • Enter the Wi-Fi password and press SUBMIT
  • You will see the Wi-Fi interface’s configuration. Make sure the Mode is set to Client.
  • If you do not want to change the received settings press Save & Apply.
  • You will see the new WAN interface’s settings. If you do not want to change the settings press Save & Apply.
After completing these steps, the router should receive internet connectivity from the Wi-Fi. In addition, you should see a new WAN interface (Network → WAN) and a new Wi-Fi interface (Network → Wireless → SSIDs).
For more information about Wi-Fi parameters and their values, view our wiki page: RUTX12 Wireless - Teltonika Networks Wiki
If you have more questions, feel free to ask.
Tautvydas
