I cannot install pip
I try to install python pip like
root@RUTC50:~# opkg -e /etc/opkg/openwrt/distfeeds.conf install python3-pip
Installing python3-pip (22.0.4-1) to root…
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/aarch64_cortex-a53/packages/python3-pip_22.0.4-1_aarch64_cortex-a53.ipk
Configuring python3-pip.
root@RUTC50:~# pip
-ash: pip: not found
root@RUTC50:~#
What can I do?
Hi, @Whaak
Welcome to community.
Have you try to type?
# pip3 --version
root@RUTC50:~# pip3
-ash: pip3: not found
root@RUTC50:~#
root@RUTC50:/usr/local/usr/bin# ls -al pip*
lrwxrwxrwx 1 root root 6 Nov 3 23:26 pip → pip3.9
lrwxrwxrwx 1 root root 6 Nov 3 23:26 pip3 → pip3.9
-rwxr-xr-x 1 root root 221 Dec 21 2022 pip3.9
I think pip3.9 is not installed correctly.
Hello.
After the opkg command… and getting a lot of
downloading https….
and
Configuring …
Have you see some error?
type python3 --version
It is working?
type python3 pip --version
It is working?
Have you try?
/usr/local/usr/bin/python3 -m pip install --upgrade pip
root@RUTX12:/usr/local/usr/bin# pip3 --version
pip 25.3 from /usr/local/usr/lib/python3.9/site-packages/pip (python 3.9)
also…
Can you look this url
Many thanks to @Marcelo.Barros for providing his input. Have his suggestions helped resolve the issues you encountered, or would you like some additional assistance?
I try it
root@RUTC50:/usr/local/usr/bin# python3 --version
Python 3.11.7
root@RUTC50:/usr/local/usr/bin# python3 pip --version
Traceback (most recent call last):
File “/usr/local/usr/bin/pip”, line 5, in
from pip._internal.cli.main import main
ModuleNotFoundError: No module named ‘pip’
root@RUTC50:/usr/local/usr/bin# /usr/local/usr/bin/python3 -m pip install --upgrade pip
/usr/local/usr/bin/python3: No module named pip
the other will also not work
root@RUTC50:/usr/local/usr/bin# opkg install python3-pip
Unknown package ‘python3-pip’.
Package installation encountered an error, removing previously installed packages.
Collected errors:
  • pkg_hash_check_unresolved: cannot find dependency python3 for python3-pkg-resources
  • pkg_hash_fetch_best_installation_candidate: Packages for python3-pkg-resources found, but incompatible with the architectures configured
  • pkg_hash_check_unresolved: cannot find dependency python3 for python3-setuptools
  • pkg_hash_fetch_best_installation_candidate: Packages for python3-setuptools found, but incompatible with the architectures configured
  • pkg_hash_check_unresolved: cannot find dependency python3 for python3-pip
  • pkg_hash_fetch_best_installation_candidate: Packages for python3-pip found, but incompatible with the architectures configured
Your python it is updated, my not… weird.
# python --version
Python 3.9.16
Please follow these instructions to install pip, as it is not included by default in the Python installation.
Setting up Python on RutOS - Teltonika Networks Wiki
Dear Justinas,
Great, your indication works
Thanks and best regards
Werner
