I accidently disabled VLAN in my RUT956 router and now the internet doesn't work
I have accidently disabled VLAN in my RUT956 router. Now the internet is not working in router and I am not able to login to WebUI. I had changed my router IP to 192.168.0.1 to create LAN with my IOT sensors.
I also performed factory reset but still cant access webUI either on 192.168.1.1 or 192.168.0.1
Kindly help.
Prity Singh
Hi…
Do your device have a password printed at label? You try to use it?
Try to look at this URL about password and recovery your device.
RUT956 Device Recovery Options - Teltonika Networks Wiki*
Thank you for reaching out!
To restore RUT956 to factory defaults, please hold the reset button for at least 12 seconds while the device is powered on. All signal LEDs need to light up before releasing. The device should be back online in a few minutes after the reset and you should be able to reach it using the 192.168.1.1 address.
You can also use RMS | Remote management system to access the WebUI of a device that is unreachable by LAN. Please keep in mind that the router must be able to reach IP addresses mentioned here: What IP addresses and ports are used by RMS? - Teltonika Networks Wiki and RMS must be enabled in device settings. To enable RMS please go to Services > Cloud Solutions > RMS Settings > Connection type > Enabled.
If you can’t reach the device after a factory reset, you must upgrade firmware with Bootloader Menu. Please follow the steps from the wiki Bootloader Menu section RUT956 Device Recovery Options - Teltonika Networks Wiki.
You can find the firmware on RUT956 Firmware Downloads - Teltonika Networks Wiki.
For more information about the Bootloader upgrade please visit RUT9xx Bootloader Upgrade - Teltonika Networks Wiki.
Please let me know if you have any more questions.
Kacper
