Huawei better then Teltonika?
Best network to connect to is determined by the modem within the RUTX50, and it is not running our software. In this case, I would recommend simply adding operator whitelist, or configuring the Manual-Auto selection in the Network → Mobile → General settings.
The problem is that I then have to manually try at each new location which operator works best. What is the best firmware for the modem?
Please use the latest firmware available here: RUTX50 Firmware Downloads - Teltonika Networks Wiki
If you are currently on an older version, please check if the behavior is the same on the latest.
Ok thanks, I installed the latest firmware of the modem. Who provides this? What is the name of the company? Maybe I will be helped there.
I’m currently at another location in Sweden. here Huawei is significantly slower than the Teltonika. It looks like it’s really random in which cell the modem logs on. can this be influenced?
