A few months ago, I created a topic titled “How to trigger SECO after losing connection with Beacon” (How to triger SECO after lossing connection with Beacon). Although I was unable to reply due to personal issues, I tested the recommended scenarios and understood that it is not possible to trigger SECO automatically, so it can only be done manually.
Currently, I require assistance in configuring at least something more basic and it is to configure the system to trigger DOUT when the Beacon signal is lost. The immobilizer scenario is not applicable as it requires specifying a number of seconds before DOUT reverts to its original state.
What I need is to trigger DOUT and maintain its state while the Beacon is in range. When the Beacon is out of range, DOUT should change its state to 0. How can I configure this?
Thank you.
