How to surpress signal strength messaging with IP Over
I am using the TRB142 with an ‘IP Over’ configuration to connect the RS232 interface to a Cisco console port. When i connect (using Telnet) i see constant LTE signal strength messages on the console.
e.g.
CSQ: “LTE”,56,-90,96,-15
I found a post which recommends using AT+QCSQ=0 to disable but how do i apply this?
Currently the TRB142 is unusable as a remote console server.
Execute:
gsmctl -A "AT+QCSQ=0"
on the trb142.
The command is accepted however when i open the ‘Over IP’ connection i still see the LTE signal strength messaging.
What is the output of gsmctl -A ‘AT+QINDCFG=“csq”’ ?
Thanks for the help so far.
With AT+QCSQ=0 the messages should have disappeared.
Could you try AT+QCSQ=1 instead ?
Do you still have those annoying messages ?
i sure do.
No idea how to work around that. Maybe you can check with ps if you have a /sbin/klogd process, if so kill it an retry the telnet.
