How to set WAN as LAN on RUT240 with R_00.07.06.15
I was able to set WAN as LAN onRUT240 with Firmware V7.0.0.5
After Upgrade firmware to R_00.07.06.15 I could not find this option at any menus on RUT240
Could you please advice me that how can set WAN as LAN on RUT240
Best regards
Hi rfprof,
Welcome back to Teltonika Networks Community!
This can easily be done by changing to Basic Mode. Then go to Network → LAN → Pencil Icon → Click Use WAN port as LAN.
Let me know if this helps.
Hello Janmiguel,
I am looking for the same option. I used to set this on the RUT240. Now I am using RUT241 with RUT2M_R_00.07.09.1.
Going to NETWORK → LAN → Pencil → in the tab “General Settings” (having advanced mode on) I dont see that “Use WAN port as LAN” option.
Should it be at the same place or how is it on RUT241?
Thank you
Are you in Advanced View?
I am in advanced view. It is not there. I switched to basic and it is shown. So I can adjust it now. Thanks. It is a little confusing, but that works for me. Thanks
Alrightie - happy you found it now :+1:t3:
