I would like to set RUTX08 in a bridge mode, pretty similar to its WiFi capable cousins, but i cannot find a setting that would easily do that. After setting the router in a bridge mode I would expect it will behave as a dumb switch. What steps do I need to do take in order to achieve that?
With these steps, your RUTX08 should function as a “dumb” switch. Just make sure to use LAN ports for this functionality, as the WAN is not configured to work in this setup. To add the WAN port to this “switch” functionality, you’ll need to configure the WAN port as LAN. Here’s a guide: LAN as WAN.
Additionally, I wanted to ask you for what purpose/situation you want to configure the router like this. Just to use it as a switch or any other use-case?
