Hello
i have rut200 Client mode connect with AP and get ip 192.168.10.100
i have plc (192.168.100.100 gateway 192.168.100.1) connect with rut200 (192.12.168.100.1) via lan port
Question
My computer connect AP and get ip 192.168.10.150, i can connect to rut200 but cannot connect to plc
i try to use static route 192.168.100.0 255.255.255.0 192.168.10.100
Hi, thank you for contacting Teltonika Networks.
You can verify at router’s Webgui that PLC device is connected to router within:
Menu->Status->Routes ARP section.
To connect to third wifi AP with Teltonika router, please check the example at Teltonika’s Wiki page: "https://wiki.teltonika-networks.com/view/WiFi_WAN_example"
Trace your connection from PC to PLC to confirm the path:
C:>tracert 192.168.100.100
If the router have been registered to Teltonika’s RMS, you can connect to third devices connected to router with RMS CONNECT, using Teltonika RMS platform.
Hope this help you.
