I use a RUTX11 in a home setting to have a cellular backup in case of an outage with my cable ISP.
I don’t need traffic prioritization when running on the cable ISP since the bandwidth is more than sufficient, but when I’m on the cellular backup, the limited bandwidth means that any heavy operation like a file download on some device affects more critical traffic like streaming on my IPTV or even normal web browsing.
I’ve given a chance to SQM with all the available scripts (cake, etc.) but it has not resulted in any improvement. Since the bandwidth of the cellular interface varies, I’ve configured SQM with the “0” value, but I’ve also tried putting a conservative value of 20 Mbps (20’000), with no visible improvements.
Does anyone have a suggestion on how I could tackle this?
I’ve read a little on DSCP priorities and how I could mark a lower priority to file download packets, but if the download goes through port 443, the firewall rule would also incidentally lower web traffic priority since it’s the HTTPS port.
Thank you!
