If you want to remove the inherited DNS servers entirely, you can do so by navigating to Network → WAN and then editing the mob1s1a1 interface. Under the Advanced Settings tab, you’ll find a “Use custom DNS servers” field. There, you can enter the DNS addresses (e.g., 192.168.0.117) to set it as your primary server explicitly. This will override any automatically assigned DNS and ensure only the specified server is used.
Thank you but Im not sure it solve the issue; I connected my phone to wifi; pinged a domain and it does not show up in adguard. If I set my phone to use the pi dns 192.168.0.117 it works but if I leave the default 192.168.0.1 it does not work so it seems that RUTOS is not enforcing strict dns for all clients
