How to distribute credits among RMS profiles?
Move RMS resources
From Companies page
To move RMS Credits or Management/Connection data packs go to Companies page under Administration section.
  1. In the Companies Page and click on and select Move resources.
  2. In Move resources action window select:
    1. Type of resource you will be moving ( Credit / Management pack / Connect data pack).
    2. Company from which you will be moving resources.
    3. Company to which you will move the selected resource.
    4. Amount of resources you will move.
    5. Click on Move button to execute the action.
At the top of your screen, you will get a notification: Move operation completed successfully.
From Company details page
  1. In the Companies Page click on View company details .
  2. Navigate to Resources tab and open Resources section.
  3. Click on and select Move resources.
  4. In Move resources action window select:
From Resources page
  1. In the Resources Page and click on and select Move resources.
Create resource code
Alternatively, to transfer resources you can use resource codes (previously known as credit codes).
From company details page
To create a code for desired resource, navigate to Companies page under Administration section.
  1. In the Companies Page click on View company details on the company you want to create resource code.
  2. Navigate to Resources tab and open Codes section.
  3. Click on and select “+ Create code”.
  4. In Create new code action window select:
    1. Type of resource you will put in the new code ( Credit / Management pack / Connect data pack).
    2. Amount of resources you will move.
    3. Optionally, you can type in comment for easier management.
    4. Click on Create button to execute the action.
Your newly created code will immediately appear in this section.
Important!
  • The code will belong to the company on which company details the code was created.
From resources page
To create a code for desired resource, navigate to Resources page under Administration section.
  1. Open Codes section.
  2. Click on and select “+ Create code”.
  3. In Create new code action window select:
Important!
  • The code will belong to the company to which your user belongs.
Activating RMS resource code
Code activation action in the account menu
Redeem code page
This method is often used by distributor users as this easily lets them provide RMS resources through a code. Codes can be activated by completely unrelated companies (companies which are not under control of the one who created the resource code).
To activate a resource code (Credit / Management or Data pack) you can either:
Using account menu
  1. Click on your account in the right upper corner and a menu will show up.
  2. There, click on Activate Code
  3. You will be redirected to code redeem page
  4. Paste the resource code you’ve been provided from someone and click Activate
  5. If the code is valid, you will receive status message “Activate operation completed successfully” and resources will be available on the company the user belongs to (can be seen in the account menu under email), to view this quickly simply click on Resource summary and you will see the increase in resources after code activation.
From the Company details page
  1. In the Companies Page click on View company details on the company you belong to.
  2. Navigate to Resources tab and open either Resources or Codes section.
  3. Click on and select Activate Code.
  4. Paste the code you’ve got and click Activate.
  5. If the code is valid, you will receive status message “Activate operation completed successfully” and resources will be available on the company the user belongs to (can be seen in the account menu under email).
From the Resources page
  1. Open Resources page under Administration section.
  2. Open either Resources or Codes section.
Other questions
  1. Do resource codes expire?
    Resource codes do not expire
  2. Can the code be only activated by my own sub-companies?
    Codes can be activated by completely unrelated companies as long as the code was not activated already.
  3. What happens to a resource code and its resources if I delete it?
    If the code was not used, resources will be returned to the company’s resource pool.
  4. I’ve created the code by accident, how can I get back my resources?
    You can safely delete the code in Company’s details page Codes tab or in Resources page Codes tab and resources will be returned to your company’s resource pool.
