Hello
how to disable “retry” on data to server?
i already disable this option but when communication back to normal router send data when lost connection. i want last data only
in normal situation if i set modbus client 2 parameter i get data like below
{“sensor_id”: “dev1”,“data”: {“TS”: “25/04/2024 13:40:51”,“temp”: “400”}}
{“sensor_id”: “dev1”,“data”: {“TS”: “25/04/2024 13:40:51”,“rssi”: “-34”}}
router will send data 2 time
when lost connection and send again
{“sensor_id”: “dev1”,“data”: {“TS”: “25/04/2024 13:41:51”,“temp”: “400”}}
{“sensor_id”: “dev1”,“data”: {“TS”: “25/04/2024 13:41:51”,“rssi”: “-34”}}
{“sensor_id”: “dev1”,“data”: {“TS”: “25/04/2024 13:42:51”,“temp”: “400”}}
{“sensor_id”: “dev1”,“data”: {“TS”: “25/04/2024 13:42:51”,“rssi”: “-34”}}
{“sensor_id”: “dev1”,“data”: {“TS”: “25/04/2024 13:43:51”,“temp”: “400”}}
{“sensor_id”: “dev1”,“data”: {“TS”: “25/04/2024 13:43:51”,“rssi”: “-34”}}
- i want last data only
2.can send all data in 1 time?
{“sensor_id”: “dev1”,“data”: {“TS”: “25/04/2024 13:43:51”,“temp”: “400”,“rssi”: “-34”}}
