How to delete a user(s) from RMS?
The Remove option is used remove user(s) from your RMS profile.
To remove user(s) go to the RMS web page, Left sidebar panel, (Users → Users) and click on Users submenu.
Move your mouse pointer to the Top control Users menu and select Remove (Users → Remove).
Instructions
  1. Select user(s) you want to remove.
  2. Move your mouse pointer to the Users menu and click Remove user.
  3. You will get a Remove pop-up window. Click Yes button to remove the user(s).
At the top of your screen, you will get a notification text: User removed.
The removed user(s) should longer be visible in the user table.
