How to configure a single SSID for both 2,4 and 5 GHz over the RMS?
in the WebUI, I can configure an SSID in one operation for both frequencies:
When reading this back to the RMS, it shows up as an array:
But in the actual configuration, I can only select a single radio:
Before selection:
After selection:
I have also tried to select both options in the dropdown with shift and ctrl held, I can only select one.
How can I configure one SSID for both Radios simultaneously?
Greetings, Marc Haber
It seems that the option to select multiple radios hasn’t been implemented yet. As a workaround, you can configure the WiFi access point through the router’s WebUI, then save the configuration on RMS as a template. Afterwards, you’ll be able to apply this template to other devices. The WiFi will include both 2.4 GHz and 5 GHz bands.
For example, if you want to create a template for a new WiFi access point with both 2.4 GHz and 5 GHz enabled, follow the steps shown in the pictures.
As for the functionality on the configuration page, I’ll contact our research and development department and get back to you once I receive their response.
