How to change to a static IP TSW202
What must I do to give the TSW202 a static IP?
Thanks for help.
Good afternoon,
If you go to Network → Lan, edit the instance, and disable the DHCP options, and set the protocol to static.
However please note, that if you will be trying to reach the switch, the PC must be in the same network subnet as the switch.
Arturas
Thanks for Your fast answer.
If I go to Network is there only VLAN ID non Lan.
Is there any other possebility to geht a static or constant IP?
hi,
Try to configure second interface called static. It should have IPv4 address field.
To set a static IP address on the TSW202 switch, you need to configure a network interface with the protocol set to Static. Here is what you should do:
Go to the WEBUI Network → Interfaces
Add a new interface or edit an existing one.
Set the Protocol to Static.
Enter the desired IPv4 address, netmask, and optionally the gateway and DNS servers.
Make sure this interface is assigned to the correct VLAN.
Save and apply the settings.
Hello Arturas
thanks for the answer. I will try to do that.
Regards
