How can I change the SIM PIN for the SIM 2.
I only know this:
gsmctl -A AT+CPWD=“SC”,“1234”,“4321”
but here I get an ERROR
Can some on help?
I only know this:
Can some on help?
Hi, this command works only on active SIM slot, so in order to change/enable PIN on SIM2, you need to make SIM 2 slot as active.
Thank you that is the trick! And I had to edit the command a bit
gsmctl -A ‘AT+CPWD=“SC”,“1234”,“4321”’
This has been working.
