How to change from udp to tcp vpn client
How can I change the vpn protocol that is connected via file.
A VPN connection that is automatically created when creating a hub
To change the VPN protocol for a connection created via a configuration file, you can follow these simple steps:
  1. Open the client .ovpn configuration file in a text editor.
  2. Search for the line:
proto udp
  1. Change the value from udp to tcp, so it looks like this:
proto tcp
  1. Save the file.
If you have additional questions or need further assistance, feel free to reach out.
