Hello, I am trying to change server location to check for response times.
It does not seen it allows me to change the server location without deleting the RMS Hub, just wondering if there is a way which I haven’t seen.
Thank you!
Egidio
Thank you!
Egidio
Hello, EgidioPerestrelo,
Thank you for your quesiton,
You can try setting up a new VPN hub with a different server and add at least one device to it for testing purposes. Please note that there is no such option, that would allow to switch between servers of RMS VPN hub.
I hope this answers your question
