I’m using my RUTXR1 as an AP for my gateway on the static IPv4 address of 192.168.1.1, so I’ve set the AP to the static IPv4 address of 192.168.1.2. However, I’d like to be able to access the RutOS GUI via IPv6 too. Although https://192.168.1.2/#/network/interfaces states that LAN connection is exposed at 192.168.1.2/24 and fd9e:51fa:be85::1/60, these aren’t possible to connect to via https://download.opensuse.org/repositories/openSUSE:/Factory/standard/x86_64/MozillaFirefox-122.0.1-1.1.x86_64.rpm even with the (presumably NAT) suffixes removed.
Consequently, how can I connect to my AP via IPv6?
