Hello, is there any way to configure a Teltonika RUT300 device to use a proxy server? I’m planning to install a Teltonika device, but the network it will be connected to only allows data transmission through a proxy server. Unfortunately, the application running behind the Teltonika device doesn’t support proxy settings.
Cheers.
We don’t currently have a solution for your request, but we’ll consider it for future updates and improvements.
Thank you for considering it.
Regards.
