shida
1
How can I get bootloader version on TRB256 7.22 with RutSDK ?
I tried follows:
# mnf_info --blver
N/A
# ls /sys/mnf_info/bl*
ls: /sys/mnf_info/bl*: No such file or directory
# hexdump -C /sys/firmware/devicetree/base/mnfinfo/blver/reg
00000000 00 00 00 02 00 01 ff f6 00 00 00 0a |............|
0000000c
Vilius
3
Greetings, @shida ,
Thank you for reaching out.
To better understand the environment, could you also clarify the following:
- Are you working with a standard Teltonika RutOS firmware, or a custom firmware built using RutSDK?
- What is the exact firmware version currently installed on the device?
- Is the bootloader version visible in the WebUI Status → System page?
Once we have this information, we will be able to investigate the matter further.
