hello,
I made a mistake on my RUT950 router and I disabled webui access. Is there any way to activate using CLI commands for editing a configuration file to reactivate webui access?
Thanks for reaching out!
After you log-in CLI of the device, please check the uhttpd directory. With below command
cat /etc/config/uhttpd
Please open the configuration file vi command and edit the uhttpd main.
option enable_http '1'
option enable_https '1'
If you’re using static IP to reach the device, please also check below lines also.
option _httpWanAccess '1'
option _httpsWanAccess '1'
Please try and let me know about the result!
Caner
Hi @Caner,
The problem is solved thanks to your help. First I modified the first two lines and it didn’t work then I added the last two lines and it worked. Thanks for the support.
I am glad I could help!
Caner
