after update of a test RUTX11 to fw 7.11, it seems that the user group bandwith limits are broken. I get full speed connection if connecting a device to the hotspot, while the max. bandwith is set to 2Mbit/s only in the respective user group settings. Worked after all past fw updates, but not after 7.11 …anyone else having this issue?
Wilfriedo
Thank you for reporting the issue. I’ve replicated the described behavior with the Hotspot’s user group bandwidth limits and have escalated the issue to our R&D team for further investigation.
In the meantime, it appears that the Hotspot user group bandwidth limit is not ignored when the Authentication mode is set to Local Users. Could you try switching to this mode and see if it resolves the issue for you?
Please note that a Local User must first be created under the Local Users tab for this configuration to work.
