Because of the location of our product, we need to have higher-gain Wifi antenna to be installed on our RUTx50.
As you know, RUTx50 comes with dual-band Wifi, and antennas have different specifications for different frequencies.
Neither on the antennas that shipped with the device, nor on the device itself, is there is no label that shows which Antenna belongs to which band (SMA connector).
My question is if we buy a one high-gain 2.4 GHz and one 5 GHz antenna, to which SMA connector should i connect them?
Could you please guide me in this regard and whether you have a preferred setup or not.
When it comes to antennas on our devices, we recommend using the antennas that have arrived with the packaging. F.E. If you connect mobile antenna to mobile port, it does not matter which port you use, as the first antenna will boost the connection, and then the rest of the antennas will boost the signal.
I would recommend testing the antennas in different ports, to check which gives you the best connection, as you are using third party antennas with which we have not tested.
Putting in all the antennas, including the high gain one, and then switching positions, but still connecting to all ports, you will not see a difference.
