Help with LAN config of RUTX50
Hey there!
I’m currently configuring a RUTX50 Device and a little bit stucked at LAN-Config. I would like to depict the following scenario. There is a WAN connection via 5G, which is used to establish an IPSec tunnel to our main location. The configured LAN IP address is 10.203.0.254/24. The IPSec tunnel works and I can access the device via the LAN IP. In addition to the 10.203 network, there is also a 10.1.92.0/23 network at the location, which is connected to port 2 of the Teltonika. How can I configure it so that I can reach the 10.1.92 network? If I configure the IP assigned to me (10.1.93.xx) for LAN port 2, I unfortunately cannot enter a gateway or ping the addresses (via the Teltonika CLI). Do I have to configure the network as a WAN? If so, how?
Thanks in advance!!
To reach the 10.1.92.0/23 network, you can configure a static route. More information can be found on our wiki page here: RUTX50 Routing - Teltonika Networks Wiki.
If I misunderstood your request and you’re aiming for something else, it would be very helpful if you could share your network topology, including devices and IP addresses. Thank you!
