Guidelines for LTE antenna positioning?
Hi there
Are there any guidelines how to position PR1AS420 adhesive antennas?
Vertical? Horizontal? X-shaped? How far apart from each other?
Thank you for your inquiry. For optimal performance, the antennas should ideally be positioned about 5–10 cm apart from each other.
When it comes to positioning, it is recommended to first test the antennas without mounting them permanently. In some cases, horizontal positioning may ensure better signal reception depending on your specific environment and setup.
If you have any additional questions or need further assistance, feel free to reach out.
